Flashing engine light
Old Mar 26, 2016 | 05:19 AM
SSxTc0825's Avatar
So I replaced my spark plugs yesterday and I noticed as I started it up I was running really rich. I was running lean before now all of a sudden I'm rich. I started driving thinking it was just my AFR catching up or something. Well I noticed when I gave it throttle, my check engine light would flash. When I let off the throttle, it would go away. I took it to AutoZone and tried to read the code. Nothing. Started driving again and the same thing happened. I'm thinking maybe my spark plugs need gapped or something? Ignition-wise, everything ran fine before the new plugs. I'm going to try my old plugs and see if they do anything different. Hopefully I don't destroy a coil or anything on my way home from work
Old Mar 26, 2016 | 07:32 AM
blueLNFftw's Avatar
It's a coil that's bad
Old Mar 26, 2016 | 08:48 AM
What spark plugs did you install? What gap? And by your username I'm guessing you have an lnf
Old Mar 26, 2016 | 12:45 PM
SSxTc0825's Avatar
I installed NGK Iridiums BKR6EIX I believe. They were gapped for stock (0.040) so I closed the gapping (0.034) and I'm still having the problem so next step is coils. I'm trying to determine which one is bad. I don't have a code thrown at all and the CEL only comes on when driving. It stabilizes at WOT and turns off but normal driving it flashes
And no the 0825 part is a date of importance for me. I have an 06 SS/SC
Old Mar 26, 2016 | 07:36 PM
Sl0wbaltSS's Avatar
If it's flashing, the car is knocking or misfiring badily. Plugs are probably screwed.
Old Mar 26, 2016 | 07:57 PM
T-fog's Avatar
Have you tried pulling codes?
You could also swap coils and see if it follows?
Old Mar 26, 2016 | 09:49 PM
SSxTc0825's Avatar
I can't pull any codes because I don't have a live data reader. The code doesn't show at idle, it only shows while driving. I thought about buying a coil and testing each one individually
Old Mar 28, 2016 | 10:35 AM
SSxTc0825's Avatar
Bump. Any ideas dead on this? I don't wanna risk anything getting damaged since it's my DD
Old Mar 28, 2016 | 11:29 AM
blueLNFftw's Avatar
Any decent code reader will show you the stored code for this.
Old Mar 29, 2016 | 10:20 AM
SSxTc0825's Avatar
I had the codes read with 3 different brand readers and nothing comes up. It's only while driving
SSxTc0825
Nov 14, 2020 02:05 PM
09SS7163
Mar 28, 2016 11:44 AM
doug41176
Mar 25, 2016 05:42 PM
redman2357
18
Mar 22, 2016 05:59 PM
jerminat0r
Mar 22, 2016 09:44 AM
