flickering lights
Old Oct 4, 2010 | 10:34 AM
mrbelvedere's Avatar
flickering lights
anyone have this problem my dash lights and park and turn and tail lights flicker heads dont they are hids alternator checked good and battery checked good any ideas
Old Oct 5, 2010 | 01:03 AM
insylem's Avatar
Only time I had my lights flicker is when the battery cable wasnt snugly tightened.
Chcekc the battery connections, and that connection where the black wire goes to the frame. If you have to take it apart and clean and reconnect securly.
Old Oct 5, 2010 | 11:20 AM
i did that but thank you for the response
Old Oct 5, 2010 | 09:07 PM
damien's Avatar
Watch for the battery light..I had this problem it took months to fully kill the alt..it even checked out good after 3 tests. Replaced it and good to go.
Old Oct 5, 2010 | 09:13 PM
Lapila82's Avatar
Wait, they're HID headlights?
Old Oct 5, 2010 | 09:20 PM
TommyP's Avatar
AWD > FWD
yes, and the hids are the only things not flickering. All the halogen bulbs in the car are flickering.
Old Oct 5, 2010 | 09:39 PM
Lapila82's Avatar
I wouldn't know firsthand but I've heard that HID's can cause problems like that, you may wanna look into that...
Old Oct 5, 2010 | 09:41 PM
Nacademus's Avatar
pull the headlight fuse... see if that fixes the flickering.
Old Oct 6, 2010 | 10:23 PM
SSchargedSS's Avatar
did you have the wire the HID's in? double check wiring, sounds like it could be a loose connection
RaginChopsuey
Oct 27, 2015 01:27 PM
brandon04
Oct 21, 2015 07:04 AM
dennis69
Oct 20, 2015 04:49 PM
z28addiction
Sep 28, 2015 12:03 AM
