Found something in my intake manifold
Old Mar 31, 2015 | 09:28 PM
Thought I had a vacuum leak so i took my manifold off. These were rattling around inside??? Anybody have a clue??
Old Mar 31, 2015 | 09:33 PM
Sl0wbaltSS's Avatar
Well I'll say you're lucky your engine didn't go kaboom.
Old Mar 31, 2015 | 11:10 PM
no_ss's Avatar
Check the top end?
Old Mar 31, 2015 | 11:25 PM
I think its the top ring. 125psi on cyl #2 and 175psi on the rest.
Old Mar 31, 2015 | 11:42 PM
Sl0wbaltSS's Avatar
Piston ring? No way that stuff could go from inside the engine, past the intake valves, and rattle around the intake manifold. it the ring broke into pieces your piston and head would be fucked right now
Old Mar 31, 2015 | 11:48 PM
Well theres really nothing else that looks like that that would be able to get past my intercooler.
We shall find out tomorrow. Ive been working on getting the head off.
Old Apr 1, 2015 | 12:36 AM
Mother of god...
Maybe.... something at the exit of your intercooler or charge pipe? Like a vband piece or something?
Old Apr 1, 2015 | 07:00 AM
I use all tbolt clamps.
Theyre curved like a ring and theyre pretty hard
Old Apr 1, 2015 | 08:25 AM
I'm guessing parts of your intercooler. Although it could be rings if one locked your intake valve open then potentially it could eject the ring material into the IM. Grab a borescope and pull the plug on #2
Also the low compression on #2 could be due to a bent rod
Old Apr 1, 2015 | 08:58 AM
The car runs fine and doesnt burn any oil, but if i rev it up it starts missing like crazy and running super rough, then it decides to calm down and run fine again.
Old Apr 1, 2015 | 09:03 AM
Im thinking now that it running rough couldve been everytime it sucked a piece of metal back into the cylinder and keeping a valve stuck open. The car literally drives fine except for a slight hesitation when you take off but while cruising every ten minutes itll start missing like crazy again but if you give it like 30 seconds all the power comes back and i can keep driving
Old Apr 1, 2015 | 11:33 AM
Big bummer dude it definately looks like a ring and only makes sense with the compression
Old Apr 1, 2015 | 11:51 AM
I just cant wait to see what the piston and wall look like
Old Apr 6, 2015 | 02:22 PM
Old Apr 6, 2015 | 02:25 PM
LNFTX's Avatar
Oh my
Sorry for your loss
Old Apr 6, 2015 | 02:26 PM
Well that's not good at all.
Old Apr 6, 2015 | 02:28 PM
07blackg5's Avatar
Slobodan Milošević
this looks familiar!
Old Apr 6, 2015 | 02:31 PM
07blackg5's Avatar
Slobodan Milošević
top ringland is thin as hell. I believe 3mm.
This is a factory 2.2 piston vs a wiseco
Old Apr 6, 2015 | 03:12 PM
Does anyone have a recommendation for exhaust manifold gasket? I was using the lnf on on my l61 head with lnf exhaust manifold, but it looks like it doesnt cover up these weird holes in the head.
Old Apr 6, 2015 | 03:13 PM
07blackg5's Avatar
Slobodan Milošević
I have the copper one ottp sells, but my 07 bead doesn't have the "holes" under 2 and 3 exhaust ports
Old Apr 6, 2015 | 03:17 PM
The holes are on the sides. This is an 07 head
Last edited by Slowbalt2000; Apr 6, 2015 at 03:17 PM. Reason: Automerged Doublepost
Old Apr 6, 2015 | 03:22 PM
07blackg5's Avatar
Slobodan Milošević
Ah, I thought you were 05-06. this is what I have:
SCE Pro Copper Exhaust Manifold Gasket
Thing seals up like crazy. I've reused it many times now and haven't had a problem yet
Old Apr 6, 2015 | 04:30 PM
I guess ill look around but thanks for the option.
Old Apr 7, 2015 | 01:27 PM
ItalianJoe1's Avatar
I think you can use a stock LSJ gasket on your head, the ports look similar. I know the LNF one doesn't seal on an LSJ head either.
That sucks about the ring, that's the first time I've seen that happen on a cobalt. VVT engine? Sometimes the internal EGR function of the cam timing causes enough vacuum to pull pieces of stuff out of the intake, seen it happen on other cars but not an ecotec yet.
Old Apr 7, 2015 | 01:51 PM
Nope this is an l61. No vvt here. And i dont think i can use the lsj or lnf head gasket...
