Front end Hops
Old Dec 10, 2007 | 01:36 AM
Rob2007SS/SC's Avatar
Front end Hops
I have what I think may be a problem. When I first got my 07 SS/SC it would break loose if I was rolling and then hit it. It would be a real clean break and then I would shift, Chirp second and go. One time I did this and the front end started to hop. Ever since then anytime I get on it in first it starts to hop pretty bad. This actually started at about 800 miles and the car now has 2800. This is not something I do on a regular basis as I am not somebody that consistently beats my car however obviously when I first got it I was taking a lot of people for rides. Since I got the car in October the weather has dropped a lot and now is usually in the 30s. I always thought that the colder the weather the more the car would spin and wheel hop was something that tends to happen when it is warmer and the car is trying to hook however a am pretty new to this FWD game as I used to own RWD Mustangs and Camaros. Please let me know if this is a cobalt thing or if you think I broke something. Thanks for all the help
Old Dec 10, 2007 | 01:37 AM
an0malous's Avatar
type "wheelhop" into the search button under "contained in title"
and start reading.
its a FWD thing.
if you ever feel it happening again, get off the throttle ASAP.
it CAN cause serious damage if you keep applying power.
Old Dec 10, 2007 | 01:38 AM
REIGN SS's Avatar
Original Hayden Fanatic
No its wheelhop it is a huge problem for Cobalts, all FWD for that matter...
Motor, Tranny, and a Torque Dampener should eliminate the issue...
Whenever you get wheel hop get off it immediatly, otherwise you will be coughing up some $ for a new axle
Old Dec 10, 2007 | 02:02 AM
I appreciate that info. I had not actually seen a thread for this yet but I will search it out. When it happens I always let off the throttle right away.
After searching around a bit I ofund that most people don't like the TD. I would like to try the motor and tranny mounts first. Is Prothane the way to go for this. This car is going to remain stock for a few years until my wife is ready for a new car and I can get my hands on this one.
Last edited by Rob2007SS/SC; Dec 10, 2007 at 02:02 AM. Reason: Automerged Doublepost
Old Dec 10, 2007 | 10:52 AM
an0malous's Avatar
if you are ok with vibrations, go with mounts.
I used the TD for a good while, i was very happy with it, especially as a daily driver mod, that will help at the track.
good thing about it, is you could remove it in under a minute if you dont like the vibs on a long roadtrip.
Mounts will be more effective with controlling wheelhop though.
Old Dec 13, 2007 | 03:01 PM
I had thought about the vibrations also but wasn't sure if it would be bad or not. Really what I want is ti to feel like it does now but without the hopping. I will have to look into this td some more if you say it will vibrate more with the mounts.
Old Dec 13, 2007 | 03:04 PM
M-Dub's Avatar
I have the torque damper and love it! No more wheel hop for me since the day I installed it!
Old Dec 13, 2007 | 03:08 PM
bgbearcatfan's Avatar
I installed the torque dampner and wasn't too impressed by the results so im going to go with mounts, hopefully you'll have better luck with it
Old Dec 13, 2007 | 03:16 PM
D4u2s0t's Avatar
torque damper helps, but my car still hopped LOTS with it. the mounts help a lot though. i'm not afraid to spin the wheels anymore. yesterday i spun the wheels all through second, up to about 65. would have never even considered doing that before.
M-Dub's Avatar
I have mine as tight as you can get it, it worked good for me! I know some have had bad luck with it, worked well for me!
Old Dec 13, 2007 | 03:18 PM
Jimmys2007CobaltSS/C's Avatar
weclome to "wheelhopping" ss
Old Dec 13, 2007 | 03:24 PM
light'bolt's Avatar
It's just a Cobalt thing..........welcome to our FWD world.....
Old Dec 13, 2007 | 03:36 PM
Forced SS's Avatar
I just got solid mounts from bwoody.the vides aren't near as bad as i thought it would be. but no more wheel hop.
Old Dec 13, 2007 | 03:39 PM
D4u2s0t's Avatar
yea i had mine set to the stiffest too, still hopped. i don't have lsd though. it was way, way better than it was without it though.
Old Dec 13, 2007 | 03:40 PM
M-Dub's Avatar
Yeah, I have LSD that might make a difference with mounts or ETDs
Old Dec 13, 2007 | 03:41 PM
^^ mine was stiffest as well with lsd and still happened..
Old Dec 13, 2007 | 04:02 PM
RaineMan's Avatar
Bwoody engine and tranny mounts... solid... problem solved.
Old Dec 13, 2007 | 04:07 PM
berto's Avatar
myspace.com/jvcougar
YEAH DON'T TRIP DUDE IT HAPPENS TO ALL FWD CARS
JUST GET A TORQUE DAMPER LIKE THE REST OF US...LOL
Old Dec 13, 2007 | 04:09 PM
Beck's Avatar
i have bwoody motor mount, both trans mounts, and control arm bushings and i have no wheel hop at all (unless the road is wet) now my biggest issue is traction
Old Dec 13, 2007 | 08:02 PM
Thanks for all the info everybody, It looks like I will be going with the TD first and then go from there.
Old Dec 13, 2007 | 08:07 PM
memphisr24's Avatar
Wheel hop has gotten really bad in my car in 1st gear a couple of times....2nd gear in my car however spins as smooth as butter. I have no mounts or a torque dampner/brace. All you pussies with the mounts...PAAAALEEEAASE lol JUST KIDDING
Old Dec 13, 2007 | 09:23 PM
RaineMan's Avatar
Don't waste your money on a dampner first... I made that mistake. Just get the solid mounts... kiss any hop goodbye forever.
Old Dec 13, 2007 | 09:49 PM
Renesis's Avatar
what dampers should we go for if we don't want big vibrations?
engine or tranny?
Old Dec 13, 2007 | 09:58 PM
Red2.4SS's Avatar
I believe that the only damper available attaches to the engine mount.
Old Dec 13, 2007 | 10:00 PM
Blur.fx's Avatar
Pave It All...
Works the other way... Colder temperatures make the tires harder, less pliable, and more prone to wheel hop.
I have to vote for the solid mount(s) though, torque dampers are just band-aids.
