front struts creaking
i have a 2007 cobalt ls coupe only has 8,500 miles on it and i notice that the front struts are creaking like crazy going over like speed bumps and dips in the road.could i have bad struts with so low miles?? anyone else had this fixed and if so what was the bad part? im going to take it to the dealer soon but just wanted to check with you guys first thanks :cssNET:
im having the same prob wit my 07 G5 it only has about 8300 miles on it. lemme knw what happens when u take it in.
its just the cold weather.
I had the same problem with my SS/SC - when it is cold outside the front end made an awful squeeking noise. Finally (after taking it to the dealership like 10 times for the same problem and telling them EVERYTIME what the problem was) they finally figured out what it was and fixed it. It was exactually what I told them it was, which is the resolution I found on this site for the same problem. It was the sway bar bushings, and after they replaced them I haven't heard one squeek or pop from my front end.
hmmm... i got it bad too
I posted up a GM bulletin that addresses most if not all of the possible noises in the front end of our cars. It describes 5 or 6 different problems that GM is currently aware of. Heres the link, just scroll down.
https://www.cobaltss.net/forums/show...=15586&page=13 |
Its the weather. My rear cracks and pops. But then again it's 2 degrees right now. When It warms up, the noises will go away.
