Fuel Of Choice!!!
Old Jun 14, 2007 | 01:51 PM
fivepointohman's Avatar
Fuel Of Choice!!!
What does everyone run in there cobalts? 87, 98, 93 or higher? Just curious. I have been running 87 since new but recently changed to 89 with seeing a performance increase, and smoother operation of the motor. Just curious.
Old Jun 14, 2007 | 01:53 PM
D4u2s0t's Avatar
i run 87. if you have the 2.2 there's not any reason to go higher than 87. it's just a waste of money.
2.4 and 2.0 should run premium. modded 2.0 depending on mods should run higher than 91.
but, you should always use the correct octane. using more than the required octane will not give you any power, and will not make your engine run any better. also, it's a big mis-conception that higher octane will clean the engine.
Old Jun 14, 2007 | 01:54 PM
h0l0caust's Avatar
i run 94.
Old Jun 14, 2007 | 02:04 PM
I agree that the cleaner engine myth is BS, this myth is definetly BUSTED... I run 89 cause I feel as though our gasoline from Hess is watered down or something, cause alot of people in my area complain about performance and economy from 87. so maybe our 89 is really 87 who knows with all these factories changing there mixes and whatnot.
Old Jun 14, 2007 | 02:08 PM
an0malous's Avatar
exactly.
but with 1 addition...
higher octane will not give you any power....
but lower octane than your engine needs, CAN take it away....
2.2 --87 is fine.
2.4 --you can get away with 89, but you will likely have knock (this is bad) and should run 91 or better
2.0 --should run 91. anything less will knock. try to find 93/94 if you can, especially if your modded. 91 octane will knock with stage 2.
Old Jun 14, 2007 | 02:12 PM
D4u2s0t's Avatar
exactly... you will only gain power from a higher octane if you were originally using lower than what you should. 99% of the time using higher octane and thinking you get more power is just in your head.
hacadacalopolis
Oct 28, 2015 06:09 PM
no_ss
Oct 18, 2015 11:58 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
jas09ss
Sep 26, 2015 01:06 PM
