Fuel Filter ?
Old Jan 21, 2007 | 02:01 AM
jojot's Avatar
Fuel Filter ?
Where is the fuel filter on these cars? Mine has 21,000 and haven't been changed yet and it has a little jerk to it when going down the road so I think it's about time to change it.
Old Jan 21, 2007 | 05:41 AM
Asphalt Assault's Avatar
The jerk to it is the fly-by wire most likely. cruising you would not notice the running out of gas feel. and on acceleration it would feel like you are running out of gas, an engine lean code would come up, and probably other codes. FYI
but I would be interested in find the filter too. I suspect it is in the tank on the sending unit and pump assembly. that is where most are put now a days. and it is likely expensive. a 99 Jeep cherokee is like 250 cdn. it is insane. you dont replace it unless it is plugged in my opinion.
Old Jan 21, 2007 | 02:06 PM
jojot's Avatar
What is fly-by-wire?
Old Jan 21, 2007 | 02:23 PM
Matty's Avatar
The filter is outside the tank.
Old Jan 21, 2007 | 02:25 PM
LaserblueSS's Avatar
fly by wire means that the gas pedal isnt actually connected to the throttle. its done electronically. im pretty sure thats what it means. someone correct me if im wrong.
Matty's Avatar
I think he means drive-by wire. Correct ssnipes?
It is the way the throttle is setup. There isn't a cable. There are 3 sensors that work with each other.
no_ss
Oct 18, 2015 11:58 PM
grampss
Sep 27, 2015 08:51 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
