Fueling Question
Old Oct 7, 2012 | 05:14 PM
RussH's Avatar
Fueling Question
Has anyone had a fueling issue after installing a larger fuel pump; namely the car going way lean after about 6K RPM with only a quarter tank or less; a half tank or more it works fine during a short WOT run?
I recently installed a Walbro 255L pump, in my 05 Cobalt; The stock pump has two strainers, one on the canister/module and the other on the pump itself. The only thing I can think of is that either the pump is sucking so much fuel that the canister can't fill back up fast enough and when it is half full or more there's enough fuel for a short WOT run. Either that or the pump isn't sitting vertical in the pump assembly.
So I wonder if anyone else has had a similar issue and what was the solution?
Old Oct 8, 2012 | 12:54 PM
RussH's Avatar
From other sources it sounds like the Walbro 255L fuel doesn't have a venturi tube for filling up the canister; so the next question is has anyone modified one of these with such a tube?
Old Oct 9, 2012 | 08:35 AM
RussH's Avatar
Well according to "the book" the venturi pump is loacated at the bottom of the fuel pump assembly and not on the fuel pump itself, so I have to assume it is driven by the return fuel; so perhaps it's restricted somewhere.
Has anyone seen this happen before?
hacadacalopolis
Oct 28, 2015 06:09 PM
brandon04
Oct 21, 2015 07:04 AM
no_ss
Oct 18, 2015 11:58 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
