G5 GT turbo issues
Old Jun 9, 2019 | 10:31 AM
Turbo yak's Avatar
G5 GT turbo issues
Hello all so I have an 07 G5GT that I have bolted a stock turbo from an SS and the piping and car is tuned with HP tuners and car passed smog the day after it was tuned 2 years ago. so my first issue:
A few months back the TB failed so I got another one and doing so forgot to disconnect the battery and now the idle is around 1800 rpms and I have driven over a thousand miles and still hasnt relearned , tried to lower it with a scanner and still nothing.
My second issue is a monitor , so the car was tuned two years ago and i hadnt had a problem until taking it in to have a smog done and all my monitors are set except the CAT wont ready , I have driven over a thousand miles and it still wont relearn and tried the drive cycle> to ad the car hadnt been touched or any work or tuning done since the first day it was tuned.
The third issue is I noticed oil in my my charge pipe and around the throttle body and from what ive read it can be a seal i the turbo or blow by and it doesnt smoke or anything so im guessing its blow by?
If theres any one out there that knows theses engines well and can help my out I will come to you I just want to figure this out and be able to drive the car worry free , if you can help me or can point me to a small shop please do thanks all!
Not sure if I posted this in the right place ...
Old Jun 9, 2019 | 02:14 PM
One thread is enough, you don't need to make three in different sections.
I'm assuming you ended up unhooking the battery in an attempt to reset the throttle body, which might cause the car to go through the oxygen sensor tests and I'm going to guess it need to idle below 1200rpm.
Did you move the throttle body blade before installing? No vacuum/boost leaks?
A little oil in the pipes is normal, the pcv system isn't the best, just watch your oil level and if it starts going down then it's time to be concerned.
Old Jun 9, 2019 | 10:25 PM
Turbo yak's Avatar
Thanks for the reply ECaulk ... No leaks I can find or hear and car idles smooth if you force it down by putting the car in gear so I dont think theres any leaks I hope not and nope never touched the blade just installed it. Wasnt sure if I was posting it in the right place thats why I made three my bad.
Turbo yak
Jun 9, 2019 10:33 AM
Turbo yak
Jun 7, 2019 09:33 PM
zgrawcock
Oct 20, 2018 02:56 AM
CalebPatton
Nov 8, 2013 07:15 PM
NobDaSkrilla
Feb 12, 2012 12:11 AM
