gas meter not working
Old Feb 29, 2012 | 10:05 AM
07LSJ's Avatar
Exclamation gas meter not working
this past weekend i replaced the gas tank of my car, and after a huge headache, i took it to a friends shop to sit there to replace the whole fuel pump, canister, etc.
yesterday when i finaly get my car back, i fill up the tank with about 11 gallons, gas even came out a little bit, and when i look at the gas meter, it stayed at 3/4.
i know for a fact its full, ive drove the car about 35 miles, and its still in the same spot.
any help on how to fix this??
Old Feb 29, 2012 | 10:10 AM
zerosk8ter83's Avatar
maybe they forgot to connect something,try unplugging the battery
Old Feb 29, 2012 | 10:20 AM
07LSJ's Avatar
ok.. ill try to unplug the battery... see if that helps.. someone told me about the bottom of the canister where the fuel pump goes, that little thing rail, maybe its messed up.... idk??
Old Feb 29, 2012 | 02:30 PM
07LSJ's Avatar
any other answers??
Old Feb 29, 2012 | 02:33 PM
i wouldn't worry about the battery its gotta be some little connection on the tank. double check everything you did and make sure you didn't miss the connection. if its an electrical connection (idk if it is) maybe spray it with some automotive electronic cleaner for a better connection. if its a manual connection it's probably the 'level measure' (idk what its caled) floating the the gas tank probably.
Old Feb 29, 2012 | 02:37 PM
Cobalt_Daddy's Avatar
lol sadly my 09 ss does this sometimes... shut the car off and a few starts later it registers full again. then take it for a drive to teh grocery store and back and suddenly the 5km i drove took it down 1/4 of a tank. dunno about yours but the gas gauges in these cars are wonky..
probably not the same issue but just thought i'd share. like others said check your connections.
Old Feb 29, 2012 | 02:43 PM
07LSJ's Avatar
^^ haha yea thanks guys, imma check the connections see wussup its driving me nutsss
Old Feb 29, 2012 | 05:26 PM
Gelladuga69's Avatar
I've had this happen to me once, although I never did any fuel work to my car.
I just accidentally stalled my car out and when I started it back up my meter was past E.
It was like that for a couple miles, but then slowly started to rise back up to the right level.
RaginChopsuey
Oct 27, 2015 01:27 PM
biniecki
Oct 25, 2015 02:23 PM
dennis69
Oct 20, 2015 04:49 PM
SSLOW06
Oct 1, 2015 07:21 PM
