gas pedal quits working???????????? help!
Old May 2, 2011 | 08:21 PM
GTDanny's Avatar
I have a 05 Colbalt and the gas pedal stops working sometimes, After a stop, I take off then about 20mph the gas pedal stops responding, I can press it down, floor it and it doesn't rev up, nothing and then it starts working again after a few seconds. I took it to the dealer and the had it for 3 days and they can't fugure out why it does it. No lights come on when this happends and no codes showed up either. It doesn't do it all the time. I'm thinking it might be in the pedal, losing power or something like that... Any ideas????? Thanks for reading this, any suggestions would be great...
Old May 2, 2011 | 08:54 PM
GTDanny's Avatar
I found a new take off gas pedal assenbly on Ebay for $20.00 shipped, I guess it's time to start swapping parts...... I'll try that and I hope this works, wish me luck...
Old May 2, 2011 | 08:55 PM
heathkidder's Avatar
it could be ur fuel pump you know
Old May 2, 2011 | 09:44 PM
NVMYCOBALTSS's Avatar
If it were the fuel pump, the engine would sputter or die.
OP, did the dealer check the TPS? My wife had a grand am that had similar issues when the TPS went bad.
Check for loose wires around the throttle body / peddle assembly as well.
Old May 3, 2011 | 01:01 PM
GTDanny's Avatar
Where is the TPS? Is it on the gas pedal or is it on the side of the TB?
Old May 3, 2011 | 01:06 PM
Chevycobaltss3's Avatar
Tps is part of the gas pedal its called a petiometer... Its basicslly a basball diamond that has a needle in it that reads voltage/ resistance and tells the.ecm where it needs to be at or where the throttle is st on cabled systems for the t.b
Old May 3, 2011 | 06:11 PM
I think that it is mounted on the side of the throttle body. not 100% sure though.
Old May 3, 2011 | 06:51 PM
GTDanny's Avatar
I got a new pedal assembly coming, I'll try that 1st then move to the TB..., thanks everyone! Danny
Old May 3, 2011 | 09:45 PM
tpete763's Avatar
I have a similar issue, but i get pedal position codes and TB codes, I've replaced both and no help yet. I thought I had it wen I put the old TB back on but it started acting up again. Let us know if you figure it out, maybe it'll help me too
Old May 3, 2011 | 09:53 PM
Ure issue sir is wiring if u replaced both or ecm related
Old May 4, 2011 | 12:35 PM
tpete763's Avatar
I figured it was something with the wiring but i cannot fond a grounded wiree for the life of me. the next nice day out im going to take all the loom off and replace it, hopefully I'll find the problem then. On a side note, I noticed when it rains out, my car runs fine and does not go into limp mode. Also, the other day I had the AC on while I was driving and when I turned it off, the car went into limp mode. I turned the AC back on and cleared the codes, problem gone and running normal again. Turn AC off again, and limp mode again. IDK if its the wiring or something with the idle now becuase the idle goes up when the AC is turned on and that seems to be the only time it will run normal.
Old May 4, 2011 | 06:14 PM
definitely weird on the ac off = limp mode... that is a new one on me. has the wiring been hacked up with a stereo install?
Old May 4, 2011 | 06:16 PM
Well when ac is on rpms go up when off they go down. So its prob a t.b issue. .. A bad part in the scaler..
Old May 4, 2011 | 06:23 PM
cranemaster's Avatar
Check fuses, including the one in your trunk (if the battery is in the trunk).
Old May 4, 2011 | 11:43 PM
tpete763's Avatar
Checked all fuses already, none are blown, I installed the stereo using the right adapters and wrapped everyting up in electrical tape when I was done. Its driving me nuts, I thought I had it fixed a few times but after I turn the car off and restart it, it does it again. I only found out about the ac because i had it on driving to work one day and when i was sitting I turned it off and that was the result I got, turned it back on and cleared the codes, and it ran normal. weird if you ask me. Should I try and get another throttlebody maybe? I bought it used but was told there were no issues with it when it was taken off of the car (guy put a sc in his 2.2)
Old May 9, 2011 | 09:43 PM
GTDanny's Avatar
Status Update....
2 days ago I replaced the gas pedal assembly that I got off Ebay for $20.00 shipped, new take off part, it looked like brand new... I also took off the throttle body and clean it good...so far so good... I hope this is the end of my problems...I have my fingers crossed!
Old May 9, 2011 | 11:45 PM
tpete763's Avatar
THats great man! I'm thinking maybe I got a bad part because I cant find a grounded wire anywhere under the hood or in the looms.
Old Aug 1, 2023 | 12:30 PM
harley1988's Avatar
There are 2 tps one is on throttle body the other is in the pedal my car is doing the same thing I thought it was a ground or the gas pedal cause when I left off and push it it works again.. and I swapped out my gas pedal recently so it may be faulty
Old Aug 1, 2023 | 12:53 PM
You necro'd a thread from 2011, I doubt the OP or any of the other posters are even active on the site. I would recommend starting a new thread and carefully describing the problem, and what you've done to try to fix the problem. It's more likely someone would be able to help, but the forum is pretty slow in general.
RaginChopsuey
Oct 27, 2015 01:27 PM
biniecki
Oct 25, 2015 02:23 PM
dennis69
Oct 20, 2015 04:49 PM
SSLOW06
Oct 1, 2015 07:21 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
