gm slotted rotors for brake pulse problem
Guest
Posts: n/a
hey guys im a service advisor at a gm dealership , gm has slotted vented rotors for the ss for all you guys having pulse problems . i dont have the part numbers but i will post them next week for you guys , but im sure the parts dept. at your dealership can find them for you .
gotta love the car tho
the part # are 19158827
19158828
19158829
19158830
19158828
19158829
19158830
Thanks Pugs, I do not have any problems yet except for a little pulsating at a 80 klms break, my service adviser wants to give me these as well and a discount for my rears,only because they keep bugging me to let them mod up my car
And who says the dealerships think negativly on this sort of thing
Originally Posted by Cobalt443
I have already had mine replaced with the cross drilled and slotted GMPP rotors for free under warranty
Originally Posted by distillion
anyone know the part numbers?
Originally Posted by g5mike
How much milage did you have on your car when they did your rotars,my dealership Barnes Wheaton alreadt told me with the pulsating happening to bring them in and they will get me these
Should I bring this up to my dealership and say "Listen, Ive been in twice already with this problem. I need a permanent fix. Can you put the GMPP cross drilled slotted rotors on?"
All the part numbers are all over the web!
http://www.crateenginedepot.com/stor..._ID=144&Page=3
19158827 Cobalt LH Front Rotor
19158828 Cobalt RH Front Rotor
19158830 Cobalt RH Rear Rotor
19158829 Cobalt LH Rear Rotor
Well, I had mine cut tdown 3 times in the abck, and 4 times up front before my dealer would finally replace them ( over 7 months and 18K miles ) and I just don't see the advantage of the rotors being slotted, drilled etc...
ONLY of you're using organic pads since they actaully gas and then the slots help. The only thing those slots do are make your rotors wear quicker. I've talked to many guys that open track higher end cars ( vettes, porsches, vipers ) and they all say the same thing.
IF you guys run your cars hard and have drilled rotors... keep a lookout for stress cracks. Successive heating and cooling can cuase it and that's not good.
At any rate... good that the dealer is able to do that for you if you want it. Not all will.
Getting ready to replace my rotors again ( 33K miles in 11.5 months ) and it's hard to find a good rotor out there.
A dealership here in NJ called Rossi. No special words to use, just make sure your brakes are legitimately f*cked up. Don't go to a dealership looking for free rotors when yours are problem free
How does it look? does it make the rears look lame?
not really....I have the polished 17's so it hides them bit. People really have to look to even know I have the GMPP rotors on the fronts
Here is an actual thread of someone with a RL that has these rotors and his opinion on them:
http://www.redlineforums .com/forums/performance-modifications/14540-installed-gm-performance-rotors.html
DANRICKARD
Oct 1, 2015 12:08 AM
