GM uses cheap aluminum
Old 03-06-2007, 11:47 AM
Fail Less.
Bika's Avatar
hairline crack in the oil pan.... didnt hit anything or put any stress on the pan. (no it didnt throw a rod through the pan )
this follows a cracked transmission case (inside the bellhousing) due to really thin metal casting. WTF happened to the metals that they are using? im so sick of GM's **** poor quality. makes me wanna buy a ******* Honda.
</end rant>
Old 03-06-2007, 11:49 AM
johnkb8's Avatar
i knew it!!!!!!!!
Old 03-06-2007, 11:59 AM
Edubs's Avatar
If things are so poorly built or wrong materials are used, why are you the first person I have heard with this issue? Not trying to bash or anything, just think that you're going to have issues with just about any car manufactured by any company. It's rough to see so many negative comments about GM on a forum about GM products. I know you were just ranting, I felt I needed to do the same, no biggie...
On another note, how did you find out about the crack? Leak on the driveway? This is exactly why I want to put an oil pressure gauge in my car...
Whelp, good luck with everything and I hope you don't end up buying a Honda!
Old 03-06-2007, 12:15 PM
Doc
Doc's Avatar
</end rant>
there are 4 letters on your transmission...none of them are G and M
please, buy a honda...make us all feel good
Old 03-06-2007, 12:18 PM
06blackg85ss's Avatar
LOL..... the only times I've ever seen a bellhousing crack was from sever extended wheel hop... which is driver abuse... not gm's fault... and its made by saab anyway.
Old 03-06-2007, 12:58 PM
Doc
Doc's Avatar
there is a local kid that dropped it into 1st at 95....it cracked like an egg.
Old 03-06-2007, 01:03 PM
AMG_Passion's Avatar
In reality, it shouldnt be stamped SAAB either...It should be stamped OPEL.
Old 03-06-2007, 01:04 PM
nramlow2006's Avatar
lol true...
Old 03-06-2007, 01:06 PM
Meatball's Avatar
My oil pan got a hairline crack in it from hitting a pothole going up an off ramp. The dealership refused to warranty it. damn our cars for sitting so low.
Old 03-06-2007, 01:08 PM
StinkBOMB's Avatar
No way would GM use cheap materials in anything they ever make. Not oil pans, and not axles either.....
Old 03-06-2007, 01:50 PM
Doc
Doc's Avatar
I hear ya, but it honestly is stamped with SAAB
Old 03-06-2007, 01:54 PM
CTCOBALTSSS's Avatar
ROFL!
That sucks dude. I hope everything gets fixed and things go back to normal.
Old 03-06-2007, 01:55 PM
Ljavy17's Avatar
Cheap materials or not. These cars cannot be driven like ****, or theyll break easily. Our trannies are so weak. Tell my brand new replaced trannie.
Old 03-06-2007, 01:58 PM
Oh I know it is. Everything on that engine is stamped saab. Somebody with access to a CNC machine, needs to make an adapter plate to bolt in a FWD 6 speed tranny out of some other car. Now that would be awesome..LOL
I remember when we replaced my buddies 5-speed in his 1500 pickup (with carbed 383 stroker) with a T-56 viper style 6 speed..AHH it was golden
Old 03-06-2007, 02:37 PM
Doc
Doc's Avatar
We seriously don't need to know about your sexual habits
Old 03-06-2007, 02:40 PM
hatrickstu's Avatar
i love how you guys were arguing (even though it was playfully) about how the pan is not GM its saab. who owns saab?
Old 03-06-2007, 02:44 PM
Doc
Doc's Avatar
thats not the point
Blue_ghost's Avatar
I thought the manual trannies are made by Getrag Gears - (Stutgart, Germany or Sterling Hgts, MI)
Old 03-06-2007, 02:46 PM
StinkBOMB's Avatar
Not in the SS S/C's. the 2.2's and 2.4's yes.
Old 03-06-2007, 02:48 PM
Tomtwtwtw's Avatar
I believe the ones in the non-supercharged cars are.
Old 03-06-2007, 02:56 PM
Blue_ghost's Avatar
OK - guess the article in Edmunds does not have the correct info.
Every Cobalt SS is equipped with a heavy-duty Getrag five-speed manual transmission. A short-throw shifter quickens the shifts, and a steep 4.05-to-1 final drive ratio increases performance off the line. Our test car was also equipped with the G85 Performance Package, which includes a much needed limited-slip differential and sporty Recaro bucket seats.
Old 03-06-2007, 02:59 PM
StinkBOMB's Avatar
Nope, if you have an SS S/C just look at it. I assure you it's a SAAB unit.
Old 03-06-2007, 03:02 PM
hatrickstu's Avatar
edmunds is the worst thing of all time for gathering car info
Old 03-06-2007, 03:04 PM
Doc
Doc's Avatar
you're right, they have incorrect info...
It is NOT a Getrag, it's a Saab design and built under the ill-fated guise of FGP (Fiat-Gm Powertrain)- GM's on-the-outs ,European based powertrain consortium with Fiat.
BUT AFAIK it's still built in a plant at/near Trollhattan Sweden ,where as the new FGP F40 6-speed (used in the Saab 9-3 Aero and Pontiac G6) is built in another FGM facility in Germany IIRC.
Saab actually calls the LSJ transaxle the FM55 and the speed gear ratios are IDENTICAL to those used in the 9-3 sold into North America, HOWEVER the Saab 9-3 has a slightly taller final drive ratio of 3.82:1 as opposed to the 4.05:1 This changes it's model designation to the FM57. I've been eye-ballin the larger F40/FM67 6-speed as a possible upgrade for the Redline for some time. It's rated for considerably more input torque, geared lower (with the exception of 1st) and has slightly closer spacing. Here's a speed chart comparing the F35/FM57 to the F40/FM67.
MU3 is the GM RPO code for the Saab F35
WopOnTour
more from The Auto Channel.com
Tougher transmission The SS Supercharged uses a heavy-duty FGP (F35) five-speed manual transmission. It has a higher torque capacity to withstand the increase in output from the engine. The gears are spaced in even increments to keep the engine in its “sweet spot” between shifts. A short-throw shifter quickens the shifts, too. The shifter’s travel is approximately 1 inch shorter than the shifter found in other Cobalt models.
Complementing the higher torque capacity transmission are two equal-length halfshafts with higher torque capacity. Their equal length helps limit the tendency of torque steer in this powerful front-drive application. The final drive ratio for the transaxle is 4.05:1.
The heavy-duty transmission and axle system support the engine’s increased torque, but also multiply the effectiveness of the power generated by the supercharger. In all, it’s a carefully balanced, uncompromising high-performance powertrain that is enabled by a racetrack-tested suspension.
Old 03-06-2007, 05:20 PM
SSinPA's Avatar
look at a saab and look at the ss/sc the shifters are identical....also the new saab 9-3 both 4 and 6 cylinders are 6 speeds now and both are front wheel drive....why couldn't we get 6 speeds?
Quick Reply: GM uses cheap aluminum
