Going swimming in my cobalt!
Old Nov 16, 2007 | 10:06 AM
05YELLOWSS/SC's Avatar
OK well I have an 05 ss/sc and there is a lake on the passenger side floor. I pulled out the carpet to see where its coming from but i found nothing. I would take it to the dealer but I dont have a warrenty and im jobless. Is there anyone out there that could shed some light on the situation?
Old Nov 16, 2007 | 10:08 AM
killianss's Avatar
oh shizzle my nizzle, dont forget the salt on the frizzle~
zach ls/ss's Avatar
thats funny you say cause i have an 06 and i also found a lake in the passenger side floor twice. i have no clue were its comming from
Old Nov 16, 2007 | 10:09 AM
redlineblueline's Avatar
its from the AC system i think there may be a TSB for it
yel-low's Avatar
either your a/c drain is blocked or cabin filter is really dirty or the seal under the cowl in misaligned try those three i would first start with the a/c drain and blow it out with air
Old Nov 16, 2007 | 10:33 AM
i will try all of those suggestions but where is the ac drain and cabin filter? And also it did rain pretty hard the past two days. Im thinking its coming from underneath the cowl but what should i be looking for when i take it apart?
Old Nov 16, 2007 | 01:46 PM
pixarwolf's Avatar
I had a little puddle on my floor last month - I took it into the stealership - they water tested it and resealed the trim molding under the cowl - $250 labor
Last edited by pixarwolf; Nov 16, 2007 at 01:48 PM. Reason: put a price on the repair
Old Nov 16, 2007 | 09:46 PM
megaman311's Avatar
I recall seeing a TSB somewhere about that.
Got it!
SERVICE BULLETIN:050138016 NHTSA ITEM NUMBER:10018663
MFG Bulletin Date: 20051101
Component: AIR CONDITIONER
Bulletin Summary: WATER LEAKING ON FRONT PASSENGER SIDE FLOOR OF VEHICLE, WATER BLOWING OUT OF VENTS (SEAL HEATER CORE COVER). *NM
Date added to datbase: 20060110
Last edited by megaman311; Nov 16, 2007 at 09:47 PM. Reason: Automerged Doublepost
Old Nov 16, 2007 | 09:48 PM
wheres a website to find the tsbs for our cars?
Old Nov 16, 2007 | 09:58 PM
megaman311's Avatar
Check out www.mycarstats.com
Old Nov 18, 2007 | 01:14 AM
Water leak: Water leaks onto the passenger side floor from the A/C housing, requiring installation of a seal between the heater core and A/C housing. (2005-06)
found this onhttp://consumerguideauto.howstuffwor...t-cobalt-2.htm
but does anyone know how to fix it?
Old Nov 18, 2007 | 01:15 AM
JRelly's Avatar
Its from the A/C , just had mine fixed a couple weeks ago. The dealer knows about it just take it to them and they will know what to do
Old Nov 18, 2007 | 01:18 AM
yeah but i dont have a warrenty and im short on cash
Old Nov 18, 2007 | 02:08 AM
JRelly's Avatar
I think its a TSB so talk to them and it may be free but if it isnt it will probably be pretty cheap
Old Nov 18, 2007 | 03:11 AM
creepySS's Avatar
i had the same problem on my car the tsb doesnt fix the problem, it drips water on the passenger floor if u keep @ any setting above the foot vent the a/c will turn automatically even if dont have the button on(this is in the manual btw)and u have the temp setting to hot what would u think is going to happen(heat+cold=condesation)so its dripping more water than is supposed to and thats why it drips inside .avoid using these settings for long periods of time!! 10 min max let me know if this info help u?
Old Nov 18, 2007 | 02:53 PM
yeah its not really a little drop here and there. It rained all day on thursday, friday the carpet was soaked, so i took it out and there was a lot of water. there has to be a huge leak but where. i thought it was coming from where the e-brake cable goes into the floor but that wasnt it.
Old Nov 19, 2007 | 04:18 PM
bump!
Old Nov 19, 2007 | 04:52 PM
JRelly's Avatar
mine wasn't a little drop either. believe me man the TSB will fix the problem. My passenger floor board would be soaked but after i took it in the problem hasnt occurred since and its been a few weeks now
Old Nov 19, 2007 | 06:08 PM
was yours covered under warrenty?
Old Nov 19, 2007 | 07:39 PM
JRelly's Avatar
yea they covered mine under warranty, but with GM recognizing the problem they should fix it for free or for next to nothing even if you dont have your warranty anymore
Old Nov 20, 2007 | 07:36 PM
CloudyDaysBehind's Avatar
Is this in the passenger front of passenger rear? I found the floor in front of the rear passenger soaked, but not the front.
07 LT - so... it doesn't seem to fall under the TSB.
Old Nov 20, 2007 | 07:41 PM
poppagun's Avatar
yellow your sig is really too big
Old Dec 1, 2007 | 05:02 PM
brownbandit9's Avatar
my driver carpet gets soaked and the headliner by the top driverside corner of winsheild at the top of the pillar with th boost guage is soaked when it rains.....how do i find were this leak is coming from..either weathering on door or sun roof...i have no clue..i can see it drip down from above the peddles so its draing to bak there some how.....please help...
its raining everyday out here...PS(no warranty)
Old Dec 2, 2007 | 12:35 AM
Im bringing my car in on Wednesday because I had a ****** waterfall coming out of the onstar microphone the other day in the rain.
Old Jul 6, 2009 | 02:47 PM
pixarwolf's Avatar
does anyone know the part number for the seal? it's summer again and I'm having the water leak problem
