Hahn Exhaust Tip Hanging Low
Old 02-27-2012, 03:35 PM
Neodous's Avatar
New Pic's
After installing my new Hahn cat-back exhaust I saw that the muffler tip was hanging a bit low. I tried to move things around to get it to sit right but with no luck. But I did get it center for the most part. I replaced the stock hanger with Torque Solution Exhaust Mount Kit 05-10 Cobalt from MP and I think that maybe the issue here. Not sure that it matters but I also have a CIA high flow down pipe as well.
UPDATE:
After emailing Hahn over and over (really long wait between emails) they said they had no idea why I was having this issue and said that they have never had any problems with the fit of this exhaust (BS!). Hahn said that the only way they could help me is if I would send them the muffler to see what the issue is. Which would leave me without my daily driver...
I had Monroe take a look at the exhaust on a lift and they are saying the exhaust does not fit right. They said there looks to be a problem with the angle that the muffler flange is welded in. The only way that they could fit it would be by them heating the whole pipe and bending it up, which would make the pipe weaker in that area.
I am going to try and call Hahn on Monday and talk to them to see if they will send me a new exhaust to correct this issue with how this one fits.
Here are the pic's.
Old 02-27-2012, 03:42 PM
gdubs's Avatar
That does not look right
Old 02-27-2012, 03:50 PM
Neodous's Avatar
Tell me about it lol.
Old 02-27-2012, 03:51 PM
gdubs's Avatar
I would contact Hahn ASAP.
Old 02-27-2012, 04:09 PM
Neodous's Avatar
I have done that and now waiting to hear back from them.
Old 02-27-2012, 04:10 PM
breds2k's Avatar
oh man that god you at least have a rear lip, if you didnt that would look super duper awful instead of just awful.
Old 02-27-2012, 05:44 PM
Neodous's Avatar
I guess that is true.
Old 02-27-2012, 05:49 PM
05Slowline's Avatar
bend the brackets not hard wouldn't be happy about it though after paying what hahn charges shoulda got zzp
Old 02-27-2012, 05:58 PM
Neodous's Avatar
Are you talking about the brackets mounted to the car? or the muffler? And I payed about the same for this Hahn exhaust that I would have payed for a ZZP.
Old 02-27-2012, 06:07 PM
05Slowline's Avatar
no the brackets on the muffler, if you bend them down it will bring the muffler up....
zzp is 349 hahn is 529, nowhere near about the same amount, and zzp's would've fit perfect lol.
Old 02-27-2012, 06:09 PM
Neodous's Avatar
Ya I was thinking about that, but I really didnt want to have to take it off again to do that.
Old 02-27-2012, 06:10 PM
05Slowline's Avatar
it isn't going to fix itself ^_^
Old 02-27-2012, 06:18 PM
Neodous's Avatar
Indeed
Old 02-29-2012, 02:51 AM
Macgyver2484's Avatar
Take the muffler off.
Use mapp gas to heat up the hangers boxed in green and bend them down to raise the muffler as high as you want. You probably don't need to heat them, but they will bend much easier and smoother to get it perfect.
And on a second note, Hahn must have revised their exhaust because my hangers don't cross. They are L shaped on each side.
Old 03-11-2012, 06:01 PM
Neodous's Avatar
I can't do that because it will lift the rest of the exhaust and hit the evap can. And I am not sure if they did revise the exhaust, but I do know it is a newer made one.
Old 03-11-2012, 06:17 PM
K-Train04RL's Avatar
It should be beside the evap canister not below it....
Old 03-11-2012, 07:35 PM
Neodous's Avatar
Its not below... So not sure what you mean.
Old 03-11-2012, 08:01 PM
09sscalicobalt's Avatar
just cut the muffler off and get the tip welded on lol problem solved
Old 03-11-2012, 08:06 PM
Neodous's Avatar
No thanks I want my car to sound good lol
Old 03-11-2012, 08:27 PM
it sounds great that way the hahn is quieter than stock...well if your a turbo car lol
Old 03-11-2012, 09:42 PM
Balt_and_Vette's Avatar
I had fitment issues with my mpx catted dp and catback. Had to heat up my dp with my torch and pull down like crazy. Also my muffler goes a little left so when I get time I'm going to heat up the hangars and fix that as well. Love the noise though.
Old 03-17-2012, 11:48 PM
Neodous's Avatar
Hahn has given me a few ways to fix the issue:
OK. Our return/warranty policy accommodates two different ways to replace such a part:
"1. You send it to us. When it arrives, we’ll inspect it for warrantable failure. Should it require replacement, we’ll send you a new one at no charge."
"2. We immediately ship a replacement. In this instance, you’d pay for the replacement, and then a refund will be issued when the defective one returns and is inspected and verified for warranty replacement. It is important for you to bear in mind that if the part you send does not qualify for warranty replacement, no refund will be issued, and we’ll ship the part back to you at your cost."
"In either case, should the part be a warranty replacement failure, we will cover related shipping costs, and provide you a shipping label to return the defective piece. "
"Please let us know what option you will choose. For the most effective documentation, this return process will be tracked via email only."
Thank you,
Bill Hahn Jr.
And just today I got a message from another member saying he has the newer exhaust system and is having fitment issues. It may seem like Hahn is having problems with there perfect fitting exhaust systems...
Old 03-18-2012, 12:06 AM
05Slowline's Avatar
if you're too lazy to bend the hangar pipes then send it back and get zzp that fits without any issues
Old 03-18-2012, 12:19 AM
Neodous's Avatar
I said this back
So if i do the 2nd one you are saying if you don't see anything wrong with it I get stuck with 2 of your exhaust systems? I can have a Chevy dealer and Monroe Muffler write a statement saying that the exhaust does not fit correctly. And I don't think I should have to pay for a new exhaust, I think one should be shipped to me free of charge with box and return postage. I payed over $500 for this exhaust and don't just have $500 to pay for a new one and I can not be without a car to get to work.
Thanks
Old 03-18-2012, 12:23 AM
Neodous's Avatar
Ok 1st you can't just bend **** and not have a problem some where else, I know this because I am not "lazy" and looked at it myself and had to exhaust shops look at it. 2nd I don't want a zzp exhaust, I don't like the sound it makes.
If it was just as easy as bending it I would have done it asshat.
Quick Reply: Hahn Exhaust Tip Hanging Low
