having a couple issues
First off I've had a bank one sensor code for months now. I replaced my down pipe with a zzp catless dp and replaced sensor, plugs, plug boots, and motor mounts. After about 5 days code never cleared even after resetting the cell. Today I took my car to get the cat put back on since the car was too loud and now its running weird. Every time I get into the throttle it boggs down and trys to cut out. Loss of power at low rpms. Like its flooding or something. All I have is a bank 1 responding too slow. I've drove the car all day every time I start it... Same thing. Cleaned maf. Looked for vac leaks. Can't figure it out. Didn't run like this before the cat was put back on. The cat is only 10 months old. Any ideas or suggestions on what to try next? 06 cobalt SS
What sensor on bank 1? Sensor 1 or 2
If it's sensor 1 it will affect the afr's and run rich
Originally Posted by thewafflesareburnt
(Post 7581084)
u replaced the one just behind the turbo or the one under the car on the downpipe?
Originally Posted by tomj77
(Post 7581099)
(Post 7581099)
Originally Posted by 06yellow_ss
(Post 7581109)
Still no luck
(Post 7581132)
Now I have p0030, p0036, p0102 codes. I cleaned my maf yesterday and messed with the purge valve today. I'm lost here.I only had one code before for the bank 1 sensor 1 and now three different ones. Any ideas?
