having a couple issues
Old Dec 12, 2015 | 08:50 PM
06yellow_ss's Avatar
First off I've had a bank one sensor code for months now. I replaced my down pipe with a zzp catless dp and replaced sensor, plugs, plug boots, and motor mounts. After about 5 days code never cleared even after resetting the cell. Today I took my car to get the cat put back on since the car was too loud and now its running weird. Every time I get into the throttle it boggs down and trys to cut out. Loss of power at low rpms. Like its flooding or something. All I have is a bank 1 responding too slow. I've drove the car all day every time I start it... Same thing. Cleaned maf. Looked for vac leaks. Can't figure it out. Didn't run like this before the cat was put back on. The cat is only 10 months old. Any ideas or suggestions on what to try next? 06 cobalt SS
Old Dec 13, 2015 | 12:16 AM
tomj77's Avatar
What sensor on bank 1? Sensor 1 or 2
Old Dec 13, 2015 | 02:04 AM
thewafflesareburnt's Avatar
If it's sensor 1 it will affect the afr's and run rich
Old Dec 13, 2015 | 09:08 AM
Its bank 1 sensor 1 upstream. I've replaced it and the code is still on. But it didn't start running like crap till the cat was put back on.
Old Dec 13, 2015 | 11:50 AM
tomj77's Avatar
u replaced the one just behind the turbo or the one under the car on the downpipe?
Old Dec 13, 2015 | 12:28 PM
On the Mani. Mines supercharged. I think I might have found the problem... I hope. I had a extension for the o2 on the downpipe after the cat to trick the computer. Then I put the cat on and didn't take the extension out. The pipe was also in a bind so when they welded the cat on they straightened the pipe out and it caused the o2 sensor to push up against the frame in return splitting all 4 wires open and shorting out on the frame. Took the extension out. Going to buy another o2 sensor now so I'll have 2 new ones at that point. Hope this solves my problem. It was surging all day yesterday also.
Old Dec 13, 2015 | 02:01 PM
Still no luck
Old Dec 13, 2015 | 05:09 PM
Originally Posted by 06yellow_ss
Still no luck
Now I have p0030, p0036, p0102 codes. I cleaned my maf yesterday and messed with the purge valve today. I'm lost here.I only had one code before for the bank 1 sensor 1 and now three different ones. Any ideas?
Old Dec 13, 2015 | 09:56 PM
Ended up being a 10 amp emissions fuse from the shorted o2 wires. Glad it was an easy fix. Guess I got a new o2 sensor out of it. Lol
vntox
Dec 13, 2015 02:21 AM
Austin2.2Ecotec
Nov 21, 2015 03:57 AM
firehawk618
Nov 16, 2015 11:21 PM
06_cobalt
Nov 13, 2015 02:28 PM
Malthaz
Nov 13, 2015 09:07 AM
