Headlight odd?
Old Jan 5, 2013 | 12:24 PM
Bluekid99's Avatar
Headlight odd?
So I unlocked my car the other night and noticed it was out so I figured ok new bulb but then I started my car and it works....I'm confused on what it could be I'm thinking a relay or something...any ideas?
Old Jan 5, 2013 | 02:53 PM
06cobalt racer's Avatar
did you try hitting the button again after you had it running? which side was it?
Old Jan 5, 2013 | 03:39 PM
Bluekid99's Avatar
Passenger and I've tried locking and unlocking and nothing I even tried wiggling the wiring and everything
Old Jan 5, 2013 | 04:41 PM
does the tail light light up on that side when u do it?
Old Jan 5, 2013 | 04:44 PM
ijak's Avatar
when you unlock, it goes high beam...when you turn on your car it goes low beam
so if you are using dual filament ...the high beam is probably burnt out while the low is still fine.
Old Jan 5, 2013 | 04:53 PM
Bluekid99's Avatar
Tail lights work and I'm guessing it could be partially burnt out
Old Jan 5, 2013 | 09:27 PM
kzak104's Avatar
unlock = highbeams, car on = lowbeams, replace ur bulbs.
Old Jan 5, 2013 | 11:44 PM
z062007vette's Avatar
Could also try turning on the high beams while the car is running and see if its out. Push the turn signal switch forward.
Pasierbek
Dec 10, 2015 07:22 PM
allpro666
Oct 6, 2015 08:11 PM
brickloaf
Sep 21, 2015 02:17 PM
jonnycat
Sep 19, 2015 12:58 PM
