headlight wiring help needed!!!!
Old Nov 5, 2008 | 03:37 PM
boostaddict's Avatar
Exclamation headlight wiring help needed!!!!
ok, so long story short, three of the wires on my buddies headlight harness got cut. Not the harness that plugs into the bulbs in the headlight, but the main harness that powers everything.
what's the easiest way to repin these wires into the clip? neither of us are good with electrical. in fact, we're terrible haha
please help! he's padiddling because he only has one headlight!!
Old Nov 5, 2008 | 04:56 PM
Maven's Avatar
Did the wires pull out of the connector or did the wires break at some point farther away from connector?
Old Nov 5, 2008 | 11:29 PM
Coblasts's Avatar
Solder a peice in if they cannot be soldered end to end.
Put some shrink wrap on them or tape them up real well.
Another option is a butt splice that will crimp the two ends together after each end is stripped slightly of its insulation. ,easiest option.
You can buy them in any auto supply store .Just make sure they are the right size for the wires you are connecting.
And use the proper crimp tool not a pair of pliers.
They are color coded and you will most likely need the pink ones.
Also tape it for good measure.
Old Nov 6, 2008 | 09:00 AM
Maven's Avatar
This is an acceptable repair(acutally the GM approved method, for wire breaks)
BUT DO NOT USE cheap butt connectors and tape! Make sure you buy the "Crimp-n-seal" or "duraseal" type connectors. These are ones you heat up after you crimp them and they shrink wrap themselves and seal connection with adhesive. They are A LOT more expensive(like $.75-$1.00 each as opposed to 25 for $3.99) but worth EVERY cent and the easiest way to make a proper durable weathertight repair
Old Nov 6, 2008 | 01:32 PM
awesome advice as always maven. I ended up just crimping them together for him, but now I think I'm going to open it back up and use these
DarrenGC
Dec 24, 2021 01:55 PM
Tupp
2.2L LAP Performance Tech
Jan 2, 2016 12:04 PM
c_m_shooter
Sep 27, 2015 04:40 PM
jmelton327
Sep 26, 2015 10:04 PM
