Help??
Old Sep 30, 2008 | 10:10 PM
dza39's Avatar
Help??
So i went to clean out my air filter, throttle body and change the plugs hoping to get ride of some bad idle problems....i put eveything back together and i noticed i went from a 11.9 AFR at WOT before, to a 10.0 AFR afterwards and worse gas mileage.....so i changed the plugs back and still have a screwed up AFR....i dont' know how that could happen...do i have a vacuum leak or throttle body leak or something....Any suggestions would be great....And When spraying 50/50 Meth does it make your AFR Leaner or Richer??
Old Oct 1, 2008 | 11:23 AM
rnjmur's Avatar
Well having a 11.9 AFR is pretty lean to begin with... but 10 is pretty rich.
I would think that spraying methanol would make your AFR appear leaner... but I am not sure about that.
Old Oct 1, 2008 | 03:24 PM
AIS's Avatar
AIS
Non Authorized / Non-Supporting
Spraying water methanol (methanol being a fuel) will make your A/F go richer. You can expect a 50/50 shot to richen your air fuel by .7-1.0 full point.
Old Oct 1, 2008 | 11:27 PM
Coblasts's Avatar
Did you re-oil the filter,Im guessing your running a cai if you got meth injection,To much oil might be restricting the filter some what or the filter is plugged up worse after cleaning it .
Just a thought.
Old Oct 3, 2008 | 11:34 PM
dza39's Avatar
i removed all the oil from the filter and left it dry and still runs like crap.... could it be a MAF senor problem, needing to be reset ot something, does the MAF control the Throttle Body??
