HELP! Car died
Old Feb 21, 2011 | 07:48 AM
R3AP3R's Avatar
HELP! Car died
I just got off work, 12 hour shift, it was raining and some ice drizzle. anyway, i left the parking lot everything was fine, and all of a sudden car just starts shaking and when i let off the throttle it turned off. barely stays on by giving it throttle.
Its a 2006 SS SC only mod is a k&n typhoon..
Any quick answers or suggestions?
(once before, a similar problem happened by driving over deeper water and had to wait till it dried out so i dont know if thats whats happening somehow.)
Old Feb 21, 2011 | 07:52 AM
cmatthewb101's Avatar
Let me guess, no hydro shield?
I'm assuming you sucked up water, and ruined the MAF. Dry it first, and see if that fixes it. Then buy the 20$ shield.
Old Feb 21, 2011 | 07:56 AM
R3AP3R's Avatar
I dont recall driving over any puddles. but thats probably a good idea anyway
Old Feb 21, 2011 | 08:00 AM
You don't have to run over water. You can still suck it water from kick up from the wheels, well, if your wheel liner is as shitty as mine But it's still the best place to start. Then clean the TB
Old Feb 21, 2011 | 08:36 AM
R3AP3R's Avatar
i see.. i hope thats all it is, and i hope its fine in about 6-7 hours
Old Feb 21, 2011 | 08:43 AM
Take it from me. I completely ruined one MAF. Then got another one wet, but it was salvagable. The 20$ Shield is well worth it. A MAF is like 70$ from Autozone. 20$>70$ Plus the piece of mind. It was worth it to me.
Old Feb 21, 2011 | 08:48 AM
R3AP3R's Avatar
obviously i dont know too much.. but whats the MAF?
Old Feb 21, 2011 | 08:51 AM
Mass Airflow Sensor.
It's connected into the intake tube. Held on by 2 screws.
Old Feb 21, 2011 | 08:52 AM
umrdyldo's Avatar
the MAF is the Mass Air Flow sensor. It is located in the air intake and detects the amount of incoming air.
Old Feb 21, 2011 | 08:59 AM
R3AP3R's Avatar
that makes sense. i guess thats what the shield would be good for
Old Feb 24, 2011 | 06:43 PM
R3AP3R's Avatar
3 days later, i changed the spark plugs since i believe the car was misfiring..
2 spark plugs were pretty badly burned, maybe the coils or the fuel pump is bad since it wont keep on?
the problem is still there.. its reving itself on idle for a few minutes then dies. got white smoke. any ideas?
Old Feb 24, 2011 | 06:46 PM
DiabeticKripple's Avatar
did you tune for the intake? i dont know if you have to but it could throw off your mixtures
denlou's Avatar
Well white smoke usually means there's coolant getting into the combustion chambers. Running rough like you said would definitely be a symptom. Once the car's cooled off, open your oil cap on the top and see if there's a white film on the inside of the cap and see if the coolant has gone down at all in both the radiator overflow and the heat exchanger overflow.
Not ruling the MAF sensor theory out, but usually something like that would produce black smoke from the excess fuel and would throw engine codes.
Old Feb 24, 2011 | 06:50 PM
R3AP3R's Avatar
well it had black smoke at first, but after the sparks changed, its white now. ill check the oil cap
and the intake has been on for over 3 years, no problems before
Old Feb 24, 2011 | 07:03 PM
bbrewbaker's Avatar
What codes are being stored?
Old Feb 24, 2011 | 07:13 PM
R3AP3R's Avatar
i didnt get the chance to look up any codes, i got a friend coming over soon with equipment.
only the check engine light comes up sometime, and sometime its off
chefhhr
Oct 26, 2015 10:36 PM
hawkssoccer11
Sep 30, 2015 12:14 PM
OrngBalt
Sep 16, 2015 07:45 PM
Getaway_Driver
40
Sep 10, 2015 09:11 AM
