Help P0621
If your needing any of the links from this, just holla. Most still point to GMDealerworld.com and prob wont work for ya.
http://fr33k.5gbfree.com/P0621.htm
fr33k
It wouldn't be the alternator overcharging would it? The trouble tree says this code is for the turn on/off of the voltage regulator is incorrect.
"The ECM/PCM monitors the state of the generator turn ON signal circuit. With the engine running, the ECM/PCM should detect a high generator turn ON signal circuit, or when the charging system malfunctions. If the ECM/PCM detects a low generator turn ON signal circuit, DTC P0621 will set."
Probe your red wire on your alternator connector with it disconnected and with the engine running and see if you have 4.5-5.5volts goin to it.
Unless your "Battery Charge" warning lamp is ON (small pic of battery) or there's a CHARGING SYSTEM FAULT message on the DTC - you can safely just ignore this DTC. (for now at least just clear it and see if it returns)
It sets sometimes when you disconnect the battery, or disconnecting certain harnesses under particular power moding conditions.
PS> Changing your supercharger pulley DOES NOT change the pulley ratio to the alternator...
Wop
Wop
