HELP---->p2135
Old Oct 6, 2007 | 10:47 AM
mastoer's Avatar
HELP---->p2135
hey guys i need some major help i keep getting this code and i dont know what to do ill erase it and its keeps comming back so it a problem now.....what im trying to figure out is what it is and if i could fix it i tried goolging it but theres no straight answer for it i know it has to do with the tps switch but thats all the info i could gather any one have an idea of whats going on ?
Old Oct 6, 2007 | 10:50 AM
REIGN SS's Avatar
Original Hayden Fanatic
its a P2135 Throttle Position (TP) Sensor 1-2 Correlation ECM, PCM.. take it to the dealer & make them fix it
Old Oct 6, 2007 | 11:50 AM
mastoer's Avatar
so basically the sensor is bad????
Old Oct 6, 2007 | 11:51 AM
ecotecon18s's Avatar
or the throttle body itself...that was bad on mine...they had to replace the whole unit...
Old Oct 6, 2007 | 07:32 PM
Coblasts's Avatar
Conditions for Running the DTC
• The ignition is ON.
• DTCs P0120, P0220, P0641, or P0651 are not set.
• The ignition voltage is greater than 5.23 volts.
• DTC P2135 runs continuously when the above conditions are met.
Old Oct 8, 2007 | 10:18 AM
fr33k's Avatar
Here's the description and trouble tree from Dealerworld. It should give ya an idea on what caused it and maybe help find a fix. Most of the links on this page wont work. If ya need to see any of them, just holla and I'll post it up for ya.
P2135
Dustonian131
Sep 23, 2015 08:03 PM
rukkee
Jul 9, 2010 05:55 PM
rukkee
Sep 21, 2009 06:47 PM
thatotherguy
May 2, 2009 09:54 PM
MadboostSS
Apr 26, 2009 07:03 PM
