HELP! reverse lights wont come on
Old Mar 19, 2009 | 01:50 AM
tdipowered's Avatar
reverse lights will not come on. i checked fuses, bulbs, wiring. what else is there? i need help i dont want a ticket....i have an sts..if that means anything
Old Mar 19, 2009 | 07:29 AM
JTob's Avatar
Reverse switch on your shifter is what tells the car to turn your reverse lights on, check that.
Old Mar 19, 2009 | 05:50 PM
Erod's Avatar
Moderator Alumni
moved. post in correct forum
Old Mar 19, 2009 | 08:54 PM
bamaboy22's Avatar
right on the top of your trans is where the sensor is. take and dont jab but take a wire and stick it in one side of the connecter and take the other end to the pos under the hood. turn key to run and put in reverse if your lights come on then change out the sensor
Old Mar 19, 2009 | 11:09 PM
Coblasts's Avatar
Like bamarmyman says but power up the Lt-green wire with 12 volts which is the B labled pin on the connector.
Old Mar 19, 2009 | 11:55 PM
tdipowered's Avatar
ok in english?
Old Mar 20, 2009 | 12:03 AM
Coblasts's Avatar
Do you know how to use a multimeter to check continuity,If so a easier way would be to unplug the connector from the reverse switch and using the meter check for continuity between the two pins or sockets on the swich itself when the car is in reverse with the ignition off.
In reverse it should show a low resistance and out of reverse it should show infinity or open conection if the switch is good.
Old Mar 20, 2009 | 07:44 PM
bamaboy22's Avatar
take a wire unplug the connecter take 1 end of wire and touch it to the inside of the connector(LT green wire) take other end of wire and stick it to the power on your fuse block. put shifter in reverse..... tell us if the lights are on
RaginChopsuey
Oct 27, 2015 01:27 PM
brandon04
Oct 21, 2015 07:04 AM
dennis69
Oct 20, 2015 04:49 PM
z28addiction
Sep 28, 2015 12:03 AM
