help with wing.(quick)
Old Sep 16, 2008 | 03:13 PM
blk ss/sc 1's Avatar
im workin on takin my wing off right now.. and i cant get the ****** thing off.. i heated it for 5-10 mins with a har dryer.. is that just not long enough or what? im also using tar and bug remover and fishing string and i still cant get it off.. what am i doing wrong?
Old Sep 16, 2008 | 03:15 PM
LamboW9's Avatar
its a super putty of silicone or some sort that they use to seal it down and they also bolt it down on top of that i belive....the putty is extremely difficult to get off especially w/o damaging anything...its why most people swap trunks for a wingless, alot of heat can cause damage to your paint but should loosen it up...im sry i cant give you more help.....suggest swapping for a wingless tho
Old Sep 16, 2008 | 03:17 PM
Fresh's Avatar
pft it's a pita!!!! been there done that and everything your tried as well. you just gotta ****** pull n tug on that bitch for awhile. i even used a large flat head to try n seperate the adhesive that holds it on. i also used a towel so the flat head wouldn't scrape the paint. i'm sure you're smart enough but you did take the nuts off the bolts correct?
Old Sep 16, 2008 | 03:21 PM
lol yea i took them off..im pullin pretty hard on it to l. i just dont wanna mess the trunk up... and im heatin it from underneath where u take the nuts off.. but it just seems like im not really getting anywhere with it
Old Sep 16, 2008 | 03:23 PM
Black08SSTC's Avatar
use some fishing line and pull it through the tar/sticky/super glue ****. just make sure to heat it good
Old Sep 16, 2008 | 03:24 PM
mkulrey13's Avatar
Bingo. Thats how i did it.
dennis69
Oct 20, 2015 07:39 AM
patooyee
Oct 15, 2015 05:11 PM
Tdubbs
Oct 13, 2015 02:31 PM
The Rookie24
Sep 20, 2015 04:33 PM
toledobalt
Sep 2, 2015 01:19 PM
