Here's one for you....
Old Jun 25, 2011 | 09:51 PM
EXsoccer1921's Avatar
oh hahah. my bad. idk how you would do it without the drain. never had to
Old Jun 25, 2011 | 09:54 PM
quikdcride's Avatar
you get it done at the dealership? how much does that usually run you ?
Old Jun 25, 2011 | 10:06 PM
outtamymind's Avatar
coolant flushes should be a menu item and should be around $149.99cdn. and there is a drain **** on the radiator which can drain the coolant.
most technicians will remove the upper rad hose and connect a coolant flush machine to it which allows the old coolant to be pumped out while new stuff is pumped in, this way all the old coolant is out of the motor and all the little nooks and crannies
no i don't do it at the dealerhship..
Old Jun 25, 2011 | 10:12 PM
quikdcride's Avatar
you do it at your house do you have a coolant flush machine? is it ok if you just let it drain out?
what kind do you put back in and how much do you need?
Old Jun 25, 2011 | 10:44 PM
should be about 9.2 quarts of coolant. coolant you should put back in is dexcool. also yes you can do it at home, easiest way is to just open the reservoir cap and remove the lower rad hose which will allow for the coolant to come out. then put it all back together and refill
Old Jun 25, 2011 | 10:51 PM
quikdcride's Avatar
where do you refill it from
in the engine bay on the right? next to the fuses?
Old Jun 26, 2011 | 12:31 AM
yup thats the only access to refill our cooling systems
Old Jun 26, 2011 | 12:33 AM
you can unattach the radiator hose where it connects to the engine so air has a way out as the coolant comes in, makes it a little easier.
SS SCHGD
May 29, 2011 10:38 AM
