hesitation when in high rpm at full boost
im not one for beating on my car and getting it up in rpm but when i do...at full boost 14psi anything over 5000rpm, the car like just stops like hesitates and then go...clutch isnt slipping its brand new but its like the entire car just wants to stop then all of a sudden goes again....any ideas?
If you don't have any check engine lights on then you can check the following.
Throttle Body, may need a good cleaning
Spark Plugs, Look for signs of oil or needing replaced
ignition coils may need replaced
fuel filter could be clogged
Check battery and alternator. Orielly and autozone type places can test your battery and your alternator to ensure they are up to spec
Do you have any other mods besides the one in your sig?
Any one else see something I could have missed?
Spark plugs, TB cleaning, and fuel filter should do the trick.
nope only the short ram and it was doing it even before i put the intake on...the car only has 39k miles on it but i guess its time to invest on the services
Try swaping arround your coil packs and Plugs to see if it follows a coil pack or a plug,
You can try the injectors as well and swap them arround too
