hid in projector problem GRRR
Old Dec 1, 2007 | 05:06 PM
defss13's Avatar
Unhappy hid in projector problem GRRR
so i get my new projectors and seperate hid kit in, and i hooked everything up after reading endless amounts of info on here. My halos, leds, and high beams work correctly, but the hid light is not working. It will come on for a split second and then turn off. I switched the ballasts and it did the same thing. The ballast makes a quick zzzz sound and then stops. Please help
steve
Old Dec 1, 2007 | 05:09 PM
an0malous's Avatar
hmmmm thats usually an indication that the bulbs are burnt out,
did you buy the HID kit brand new?
that ZZZZt sound is your ballasts working, and trying to ignite the gasses in the bulb with a high voltage spark, but as your bulbs slowly wear out, the electrodes wear down, making the gap between them further and further apart, until eventually you dont have enough voltage to span the gap and ignite....
Old Dec 1, 2007 | 05:24 PM
defss13's Avatar
yeah its all brand new....im going to try and put in a 20amp headlight fuse when i get home from the blues hockey game and see if that does anything.
Old Dec 1, 2007 | 05:37 PM
an0malous's Avatar
it can also happen if the ballasts/bulbs are not getting a good solid connection.
definately recheck your wiring.
Old Dec 2, 2007 | 01:55 AM
defss13's Avatar
well i tried changing over to 20amp fuses and it still does the same thing. On top of that, one of the halos burnt out. YEAH. this sux... i guess i'll be sending the kit back for new bulbs and while im doing that i'll try to change the halos at the same time. Are the aftermarket bulbs for the halos junk too, or is it just the ones that come with the projectors?
turbochargedss2012
Sep 20, 2023 12:17 PM
yellow dragon
Sep 28, 2015 09:49 PM
Iceberg
Sep 28, 2015 01:31 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
