Hid relay harness help
Old Jul 18, 2013 | 07:14 PM
scotia_ss's Avatar
Putting a relay harness in 9007, where the blue plug is where you put your stock plug, it has two wires coming off of it 1 foot long black and red. Don't know if I leave these disconnected or what? Any advice
Old Jul 18, 2013 | 07:52 PM
10CSSTC's Avatar
Too vague, need better explanation/pix
Old Jul 18, 2013 | 09:14 PM
scotia_ss's Avatar
those are the two wires everything plugged in and then there are those. already have a cable hooked up to the battery post and one grounded so i dont know what these could be used for
Old Jul 18, 2013 | 09:49 PM
10CSSTC's Avatar
Need info about your hid setup, this a hi low or just low. That is basically the input for the harness to know when to kick on and off. Judging by only two wires, its a low only kit. In short it plugs into the stock harness coming from the car that would normally plug into the bulb
Old Jul 18, 2013 | 11:00 PM
scotia_ss's Avatar
Got just got hids in stock housing for now bi xenon. Do I just leave these loose ?
Old Jul 18, 2013 | 11:10 PM
Might as well try and if they work then tape those up and leave them.
Old Jul 19, 2013 | 09:39 PM
10CSSTC's Avatar
It depends if they are low beam only you don't even need a harness, you can just plug the ballast straight until the stock connector. My setup is hi and low with and independent harness for power.
My setup has one plug from the hid harness to the stock harness that acts as a remote to tell the relay when to kick on and switch to high beams etc. Your is hard to tell. Post a pic of the harness
ineedacobaltss
Nov 7, 2015 02:25 PM
chefhhr
Oct 26, 2015 10:36 PM
dennis69
Oct 20, 2015 07:39 AM
dieGone
Sep 23, 2015 10:20 AM
Jeffwills14
Sep 6, 2015 06:52 PM
