HIDS with relay
HIDS with relay
ok so i ordered 2 sets of 55w hids from buyhids.com for my gen 1 headlights and my foglights. well i read the how to and every thing but my relay and my bulbs have extra connectors that i have no idea where they go. does anyone have a recent how to for installing these because apparently they have changed a few things from when they made the how to.
here is what i have to work with. im not sure where the little spade connectors go and i have the 2 connectors that would normally go into the ballast without a relay but where do they go now?
I believe those spade connectors are used if u dont have the relay harness, they would tie into your stock setup but as you have a relay harness they are not needed.
Someone please correct me if im wrong.
whoa wait a minute lol the spade connector on the relay harness should connect to your stock blue plug...seems you wer esent the wrong harness.
upon further inspection, the relay harness is def missing the Blue 9007 plug. which should be where the two spade connectors are.
and as for the spades on the bulbs those would have been used if you didnt use a relay harness.
royce777
09-28-2015 07:11 AM
