Horn will not work.
Old Oct 27, 2010 | 05:51 PM
D_sean257's Avatar
Horn will not work.
Okay soo last night I was driving around and seen one of my friends and went to hit the horn and it worked but then cut off while I was still holding it in. Hasnt worked since. Fuses are good. Connection is good.. Any ideas?
Old Oct 27, 2010 | 05:52 PM
gwatson650's Avatar
you need more horn fuel.
Old Oct 27, 2010 | 05:53 PM
Lapila82's Avatar
Check the fuse in the engine bay. If that's all good, take off your driver's side headlight and check to make sure the horn is plugged in and not loose. If THAT's all good take the center of your steering wheel off and look. If THAT is all good, get an airhorn and just hang it out the window and blast when needed.
Old Oct 27, 2010 | 05:57 PM
D_sean257's Avatar
I literally done all of that in the same exact order about 15 minutes ago lmaoo. ****.
Old Oct 27, 2010 | 06:03 PM
Lapila82's Avatar
Lol are you SURE the fuse is good? Last suggestion would be bring it to a dealer. Oh and if you know how to splice wires yourself (2 wires for the horn), I would seriously go to the junkyard and buy a Monte Carlo horn. Best $2 investment I ever made. My car sounds like it has more ***** than my dad's STS.
Old Oct 27, 2010 | 06:07 PM
D_sean257's Avatar
yes I can splice wires lmaoo. My uncle has an old ass monte carlo just rotting away I may go take the horn off of it.. I am going to check the voltage first and make sure it has power coming from the connector. if so Id say the horn is just broken.
Old Oct 27, 2010 | 06:10 PM
Lapila82's Avatar
Yeahhh. There could be something wrong with the actual connection in the steering wheel too. You checked that for sure?
P.s. I got mine out of an 05 Monte.
Old Oct 27, 2010 | 06:13 PM
D_sean257's Avatar
this is an older one with the box body style.. wonder what it sounds like? hmmm..
but Yeah I took the air bag off and all connections were good there too. no loos wires and grounds were all good.
Old Oct 27, 2010 | 06:19 PM
Lapila82's Avatar
Hm, is there any wiring exposed? And is it raining in your area? Try taking the fuse out and flipping it around, just for ***** and giggles. And whatever horn you take should have 2 black shell-like things (for the ballsy dual-tone) and it needs to have a black and a green wire in order for it to work easily.
Old Oct 27, 2010 | 06:22 PM
D_sean257's Avatar
nope all was good. and yes it was raining last night. I also think that when I pulled the fuse I might have flipped it around on accident anyways.. Didnt think about this but my grandma has a cobalt so Ill probably switch her and see if hers works. Hopefully it is just the horn and not wiring somewhere..
and if it doesnt work. my face will look like stephen colbert in my sig =o
Old Oct 27, 2010 | 06:24 PM
Lapila82's Avatar
Lmao. Well yeah just keep ******' around until something works. If not, go see the stealership so they can warranty it.
Old Oct 27, 2010 | 06:27 PM
D_sean257's Avatar
Wonder if they would keep my car very long. I HAVE to have my car everyday. I know its just my horn but its really annoying knowing that it doesnt work.. on my way home from work today I passed by and the neighbor waved and I tried to tap the horn and it didnt do ****. Now my neighbor thinks im a dick id say.. lol
Old Oct 27, 2010 | 06:31 PM
Lapila82's Avatar
Call tomorrow and make an appointment for Saturday morning, they're usually pretty quick with that **** cause they wanna get out by noon.
Old Oct 27, 2010 | 06:32 PM
D_sean257's Avatar
Sweet. well Im about to switch horns and see. hopefully I can figure this out
Old Oct 27, 2010 | 06:35 PM
Lapila82's Avatar
Yep, good luck, keep me posted lol.
Old Oct 27, 2010 | 07:00 PM
D_sean257's Avatar
okkay so I swapped the horns and hers worked.. crazy thing is.. I decided Id hit it a few times and try it again.. so I took a wrench and smacked it a couple of times.. put it back on and it fcking works.. WTF. Owell I am just glad it is working again lol... maybe something was stuck or loose or something. idkk
Old Oct 27, 2010 | 07:34 PM
D_sean257's Avatar
and if it does it again ill know how to fix it lol
Old Oct 27, 2010 | 08:15 PM
Lapila82's Avatar
Lol that's fucked up haha. Glad you got it working though!
Old Oct 27, 2010 | 08:18 PM
D_sean257's Avatar
haha for sure, thanks for the help though
Old Oct 27, 2010 | 08:21 PM
Lapila82's Avatar
Any time bro.
RaginChopsuey
Oct 27, 2015 01:27 PM
chefhhr
Oct 26, 2015 10:36 PM
dennis69
Oct 20, 2015 04:49 PM
zdohare
Sep 23, 2015 11:31 AM
brickloaf
Sep 6, 2015 05:55 PM
