How to cure Fogging headlight?
Is there a sure fire way to cure a fogging headlight? I've herd drilling a hole in the button of the housing can help
Does that actually work?
Stock headlights arnt even 100% sealed so y don't they fogg?
Did it right the first time lol, new Oem sealant and I even silconed the edges as well
But even stock headlights are not 100% sealed there's a hole right under where the headlight bulb slides in
A tiny, tiny hole on the bottom is your best bet. You just need enough to get some air movement in there, nothing drastic. You're not trying to drain the moisture out, just get some air in.
I can garruntee that the headlights are sealed , we had a wicked storm here a few days ago I've
Had them in for a month or so now, can power wash um fine
No issues it was just after a wicked storm so I dunno
I used new
Oem sealant and siliconed the edge afterwards
I used new
You have to create airflow, to keep the moisture down. If you only open one window in your house, you aren't going to get much breeze though. Same with the headlight. The one hole around the bulbs is only going to let moisture and air in. Drill a tiny hole, and it will allow the air to flow though and keep the moisture from forming.
If you seal the lights 100% totally then when the air pressure within them changes the natural moisture in the air within them condenses out, fogging them. You don't want them to leak, but they do need to breathe.
How exactly is water going to travel UP the headlight though a hole in the bottom? Yeah.
XStylus
Forced Induction
Sep 16, 2015 06:19 AM
chris88z24
Sep 8, 2015 01:55 PM
