how to tell if my ic pump is broke
so i been having little heating issues so i noticed that the coolant isnt flowing threw the neck by the supercharger.so i researched what i could find and jumped the fuse to see if i hear it turn on and when i did nothing happened.so i went and hit it with a hammer and it started to make like a spinning noise for over 10 seconds and then it would stop.
so how can i tell for sure if its not working
corn gas ftw....
Go under the car and smack the IC pump with a hammer and check if it's wired properly (I guess some of them were wired wrong from the factory). It works as a temporary fix. OTTP sells new ones.
Joel
Edit : Just re-read thread and it says you smacked it already. Make sure its wired up right though.
Joel
Joel
Joel
thats normal man. you need to be worried if they get up around 220 or higher and stay there. theyll stay low if you are moving because of the increased air flow
like when i got the car is stayed at 175 sitting in traffic or after a couple pulls it never moved for months stayed at that then randomly it got to 245 and just goes up and down
if you turn the key too on with the engine off after you drove it for a bit, you should here a high pitch whine and coolant bubbling at the neck
corn gas ftw....
yea the coolant temp on ur dash is for the engine
the ic pump cools the sc system, not your engine
the coolant in the ball shaped container to the right of the engine bay is what cools your engine...
so if your sc system gets too hot then your boost will fall and you will have a constant herat soak...
corn gas ftw....
yea its not bad, but without it you wont have any power lol
my buddy had a dead ic pump at the dyno once and with 2.85 pully, h/e, 60s, ect... he put down 194hp lmao so dont forget about it!!
