Huge problem!
Huge problem!
heres the scope:
i have a 2006 chevy cobalt ss/sc bout 70,000miles on it. about a year ago, i added an injen cold air intake. 3 months after adding the intake i hit a huge puddle of water. i did all proper steps i installed a new filter, this time with a hydro shield cover. i have used SEAFoam to rid any water (if any) that may have been in engine. i had a code for my MAF so i cleaned i installed a new one. still have this problem: ONLY, when it rains/snows or the roads are wet does it occur. after driving on wet roads and allowing my car to sit for excess hours/over night. i start my car and it idle hunts. i sit there while it does this over and over, finally i begin to drive as i drive the engine cuts in and out and the entire car studders and refuses to go anywhere, not until the car has hit 140degress will the engine light kick on and the problem goes away. again i stress it only happens when there is water on the roads. i've changed the MAF SENSOR, bought a new filter with a hydro cover. neither i or my mechanic can figure out what the problem is. SOMEONE PLEASE HELP!!!
^^^Do this. If the problem still exists, then there's something screwed up mechanically. If the problem goes away, you're still getting water in there.
Hydroshields aren't God mod. If it's ONLY doing it when there's moisture on the roads, then I'm guessing there's still moisture getting into the intake.
Mitch
Build a sheild out of plastic to stop the flow of water into intake had to remove my cold air intake for a brief little bit because of this issue built a shield to keep water from hitting it and problem solved. You are getting water in intake hydro shield is basicly useless my hydro shield didn't do anything still had an issue. I couldn't even go through a car wash.
not sure what a tune up could do, ive had multiple since installing my intake. its defiantly a mechanical issue. i just dont know what. i cant seem to figure out why water keeps getting in. it basically is within a plastic shield, its encased behind the tire. should i have gotten a short ram instead? i cant figure out why mine is the only one having this issue. no-one else i know has had a problem with their intake like i do mine. there is a mechnical fault and i dont have a clue what it is
You said you checked/replaced the MAF and filter, just for ***** and giggles have to inspected the throttle body to see if you're getting water and presumably dirt in there?
OK now since alley you said you dont have to tune for the intake ( you are corect) But i promise you he would be alot smarteer if he did..... WHY? Because his fuel trims will be out a possible -20/+20 ive seen it nd i was like really holy ****. And if fuel trims are out this much it can cause detonation which can cause a blown engine. Would most think that it can happen no, in reality its a possibility of like 10% but it can happen. Also with a tune he can get the great feel of being tuned for it, but also having the perspective of seeing a stock car with intake vs the intake with tune. SO IF I WERE OP ID GET THE TUNE. OR PUT THE STOCKER BACK ON.
so wait would a vaccum problem, or throttle bottle issue only occur when there is water on the road? thats the only time i ever have this problem. its weird. like this morning driving in after a rain storm last night it was happening. and i noticed that onces the coolant temp hits 140 everything goes to normal but my check engine light kicks on. i check the code and it comes up (MAF or VA) i cant remember the code its like PA101 or something
Then I would also clean the throttle body and put the stock intake back on.
EDIT: by connections I am not talking electrical connections. I'm talking about fittings and clamps.
