HVAC Issues please help ( not ur normal ones)
Old Jul 20, 2017 | 08:24 PM
Joey Hono's Avatar
Ok ill make this as easy as possible
1) condenser still works ice cold
2) HVAC moto when directly connected to a 3s lipo (11.7 v) works
3) checked all fuses, 10, 16, the big one 31 all good or replaced
4) checked all fuses in engine all good
the power leads to the HVAC motor do not give out power, and its driving me mad where to look or what to replace?
thank you
Old Jul 20, 2017 | 09:18 PM
Henry3959's Avatar
Not sure what your trying to say is not right but the condenser should not be cold. Do you mean evaporator?
Is the motor blowing air?
Not blowing air where you select it to?
Old Jul 20, 2017 | 11:29 PM
Joey Hono's Avatar
the actually AC unit still makes cold air, the HVAC fan under the glove box gets no power in put from the controls on the center console. However if i hook the HVAC fan which is under the glove box directly to a 12V source, it works, and blows out the cold air from the ac unit. The control to turn from lower vents to upper vents still work, as well as the use air from the cabin button >
its not a fuse i have checked all, so some thing is causing the HVAC fan not to get power when the dial is turned
Old Jul 21, 2017 | 08:13 AM
likely either a break in the wire or the selector on your hvac control is busted.
Old Jul 21, 2017 | 10:50 AM
Henry3959's Avatar
What year and model are you driving? I'll pull a schematic. This is easy stuff for me.
