I feel like I cant have nice things
seriously I feel like Im not alowed to have nice things every time I spend the money to do somthing nice to the car somthing breaks somthing goes wrong and it is really i mean really really discouraging, today I went to the gas station to fill up and I always check my oil while I fill up but today I found that there is not enough oil in the oil pan for it to even show on the dipstick so I drove it home looked for leaks and gess what I found looks like I lost the turbo seals on a brand new under 500 mi turbo FML I just baught this new from ZZP last month
feeling a mixture of feeling like a combination of
Gotta look at the pros and cons. Sure what happened was an unnecessary evil; but in my opinion when dealing with a car you have to live by Murphy's law, especially in late model cars in which the motors continue to become more technical and the intricacy of design increases. The more moving parts, the more likely something will break/fail. On the bright side, you could have just purchased a $2000 turbo kit and had this happen. At least it happened on the cheapest turbo to replace for this car.
Just my .02
Just my .02
zzp said to upgrade to a larger oil return hose, im curently using -8an line which is the same inside diamiter of the LNF but they said I should upgrade to -10an or larger
I am unclear as to how this will fix the issue you have unless the line is plugged. You have the same diameter oil drain line as an LNF with the same turbo so it should be 100% fine.
If it drains to the same location, if it drains to a different location in the block there could be some issues.
