I lost 10 psi??? I need help please
Old Dec 19, 2008 | 11:10 PM
Gixxerboy02's Avatar
Here is the deal..My car normally boosts right at 19 to 20 psi...For some reason it will only boost to 9 or 10 psi. You cant tell ant differance unless you get on it. It runs just fine. I dont know how long it has been doing htis. I dont drive it hard very often. It has 16xxx miles on it and my mods are in my Sig...Anybody have any ideas? Or has anyone had this problem? Help me please...lol
Anybody???
Last edited by Gixxerboy02; Dec 19, 2008 at 11:19 PM. Reason: Automerged Doublepost
Old Dec 19, 2008 | 11:17 PM
Erod's Avatar
Moderator Alumni
descriptive title would help a lot. moved to problems and service
Old Dec 19, 2008 | 11:26 PM
lsjwannabe's Avatar
Do you have a stg2 belt or oversized tensioner? is the boost holding steady or dropping off?
Old Dec 19, 2008 | 11:32 PM
I have a oversized tensioner pulley.. It holds steady at 9 or 10 psi.. The car has been modded for over a year with no problems.It also has new plugs if that matters
Old Dec 19, 2008 | 11:41 PM
lsjwannabe's Avatar
Have you checked your bypass sylenoid
Old Dec 19, 2008 | 11:48 PM
No i have not started checking anything out just yet. Figured i would get on here first to see if anyone had some idea where to start
Old Dec 20, 2008 | 12:01 AM
lsjwannabe's Avatar
Thats the first place i would start
Old Dec 20, 2008 | 01:07 PM
Bump...Any other ideas??
Old Dec 20, 2008 | 01:09 PM
chris88z24's Avatar
It could also be a faulty boost gauge... does the car feel noticably slower when you step on it?
Old Dec 20, 2008 | 01:12 PM
Yeah it does not pull no where near as hard as it should..It dont miss or studder or anything though
Old Dec 20, 2008 | 01:23 PM
M88ArRamadi's Avatar
definately check your boost bypass solonoid
Old Dec 20, 2008 | 01:25 PM
Why would that go out so soon?? It only has 16xxx miles on it...Where is the boost solonoid located?? How do you know if its bad?
Old Dec 27, 2008 | 03:14 PM
Toolism's Avatar
bump, totally need to know where this solonoid is, no serious mods but definitely lost boost/never had it
Old Dec 28, 2008 | 04:04 PM
Ok i did the boost bypass by unplugging the line and blocking it of. I got all my boost back..Next question is where can i buy a new solenoid and how much do they cost?? My wife has a 07 ss/sc. Im thinking about swapping them out and taking hers to the dealer.Its still under warranty lol
Old Dec 28, 2008 | 04:06 PM
pimpnwink's Avatar
now that would be win.
Old Dec 28, 2008 | 05:00 PM
Yeah i rather just buy a new one though..To much hassle. Where can i buy one???
Old Dec 28, 2008 | 05:02 PM
AjSS's Avatar
dealership
Old Dec 28, 2008 | 05:08 PM
can i get one from a local parts store??
Old Dec 29, 2008 | 05:16 PM
Ok i changed the boost solenoid and it did not fix the problem...I said F it and just did the boost bypass mod..Any long term negative effects i shoild be worried about???
Old Dec 29, 2008 | 05:20 PM
1badBlueberrySC's Avatar
I was just gonna tell you to try the boost bypass mod... There can be some negative effects so I would do it for now and try to figure out what is causing the issues!
Old Dec 29, 2008 | 05:25 PM
What are the negative effects???
Old Dec 29, 2008 | 05:26 PM
To be honest it is just there to prevent over boosting...
Old Dec 29, 2008 | 05:27 PM
Psykostevo's Avatar
Did your cooling pump crap on you, because that'sa symptom of severe heat. Car will permanently reduce boost if it sees the extreme heat from a dead intercooler pump.
Old Dec 29, 2008 | 05:28 PM
Yeah, the 2.7 is a heat generatin' S.O.B. Start the car and make sure the fluid is flowing through the H/E fluid neck!
Right on man.. good looking out..Any ideas on what the problem might be? I would liketo fix it right but no luck so far...
