IAT2 seem too high
Old Apr 5, 2007 | 05:56 PM
NightriderCobaltSS's Avatar
IAT2 seem too high
its about 60 degress outside and for some odd reason my IAT2 have been hittien around 160 . i mean i do sit in traffic alot on the way home but while im drivein it will lover to like 150 and stay , im not getting any cels any and my coolant levels seem fine and my coolane temps are around 185-195 i have 60's witha 2.8
Old Apr 5, 2007 | 05:58 PM
intense_SS's Avatar
sounds like its time for meth or cryO2 for you buddy!! it will take care of your heat problems!!
Old Apr 5, 2007 | 05:59 PM
but is with a 2.8 and when i drive it use to go back down to like 110-115 but now ut stays at 147 - 150
Old Apr 5, 2007 | 06:00 PM
bluecobaltss06's Avatar
The temperature outside is also going up as well don't forget
Old Apr 5, 2007 | 06:01 PM
saturnpappa's Avatar
Sounds like a broken intercooler pump....
Old Apr 5, 2007 | 06:08 PM
how would i dianose that? also no CELs
Old Apr 5, 2007 | 06:11 PM
Not sure about the cobalts but in my ion redline there is the intercooler filler neck. Stand in front of it and look and see if coolant is flowning with the engine on. You can even pinch the left side passenger hose to see if coolant fills the neck.
Old Apr 5, 2007 | 07:05 PM
o.k i did that and coolant fills the neck what next ?
Old Apr 5, 2007 | 07:06 PM
ItalianJoe1's Avatar
You need a dual pass intercooler mod!!
Old Apr 5, 2007 | 07:08 PM
with 60's and 2.8
Old Apr 5, 2007 | 07:14 PM
You shouldn't, i never had it until recently. But it will help lower your IAT2 temps.
Check the clip on the intercooler pump itself. Make sure it is plugged in ALL THE WAY. Mine wasn't from the factory, and after enough movement burned out the pump. I thought the pump died again one day, then i looked under there, saw it was plugged in, so I started the car and could feel the pump start when I wiggled the clip a little. I forced it on hard as hell till it actually clipped in place and have never had a problem since. Maybe that could cause the sudden changes. I would think 140-150 at regular cruise is too much.
Old Apr 5, 2007 | 07:17 PM
ok can u take a pic and show me what you mean i a little slow
Old Apr 5, 2007 | 07:22 PM
you should be able to look in that filler neck and be able to say to yourself "oh yeah its flowing" if you have any doubt then most likely your IC system is not flowing. Best thing to do is go to red-lineforums.com and do a search for IC pumps . You will find tons of information about this problem.
Old Apr 5, 2007 | 07:32 PM
What i did notice too is my IAT1 are usally the outside temp but for some reason it 60 outside my IAT1 are 100 and my IAT2 was like 145 -160 while driving. here are some pics i didnt see any loose connections
Old Apr 5, 2007 | 10:55 PM
OK, no I meant the electrical connection to the IC pump on the front of the engine, on the bottom. Can't get pics, too dark. Look under the car, from the front, there is a little black soda-can sized pump with two coolant hoses on the drivers side and a clip/wires on the passenger side. Make sure it is plugged in tight and not moving. That is part of the problem I had.
If your IAT1 are high, check the air box, maybe something is blocking it or something. Make sure the filter is clear and in the right place.
Last edited by ItalianJoe1; Apr 5, 2007 at 10:55 PM. Reason: Automerged Doublepost
Old Apr 5, 2007 | 11:01 PM
NJHK's Avatar
Just curious...
Do you have a EGT probe/unit?
Also, what is your a/f ratio during cruising and wide open throttle?
Old Apr 6, 2007 | 07:16 AM
2K5SS/SC?'s Avatar
Those temps are normal for the 2.8 w/ 60's and no intercooler mods. You are just fine man. I've been logging around those temps, but just a little less since I have the dual pass mod.
Old Apr 6, 2007 | 09:57 PM
BlilBT's Avatar
Sitting at Idle I Get 125 Highest with the Dual pass system & a 2.8!
This is at 86 Degrees out!
Old Apr 8, 2007 | 03:35 PM
I belive i have found the issue but i will keep monitoring it. When i look at a friends IC resivor he seem to have more coolant in the little spiiket when he car was trun on then i did so when the car was cool i added a little more coolant and since then it has been acting fine. dont know if that fixed it but so far its been alright
Old Apr 8, 2007 | 03:56 PM
2K5SS/SC?'s Avatar
I have those numbers at idle with the dual pass mod. Under full boost without the dual pass mod though, 160 IAT2's are normal.
Old Apr 8, 2007 | 03:59 PM
BlilBT's Avatar
I Know wasn't telling what they should be! Was showing him were you can get them!
Old Apr 8, 2007 | 04:06 PM
hey guys thank for the help . but do yall got the standard dualpass or the performace dual pass with the extra resivor
Old Apr 8, 2007 | 05:18 PM
2K5SS/SC?'s Avatar
I'm running the standard homemade dual pass setup.
Old Apr 9, 2007 | 07:42 AM
BlilBT's Avatar
I'm running the Performance 1!
Old Apr 24, 2007 | 04:42 PM
THE PROBLEM HAS BEEN FOUND AND REPAIRED UNDER WARRENTY MY IC PUMP FAILED THAT WHY MY IAT2 WERE SO HIGH !!!!
