Im Fking Pist
Old Nov 2, 2006 | 10:18 PM
biohazard's Avatar
Get low
Im Fking Pist
ok so some of you know how ive had all the fking problems with my car, well my new radiator came in today. i payed for 2 day shipping and everything so i can get this thing running. i havnt had my car for weeks.... well everything was going fine but the tubes for the trans cooling dont fit into the new radiator! the new radiator has holes that are like 1 size too big for my coolent lines..... so now im sitting here completly fking hopeless on this car now it fking hurts when you think your finally getting your car back and you dont because of somone elses mistake..... all the company that sold me the "OEM" part offered was my money back.... but im out shipping! F**K THAT
Old Nov 2, 2006 | 10:21 PM
HackAbuse's Avatar
block off the coolant hookup, and get an external tranny cooler
victory_red_SS's Avatar
LSX RWD S/C conversion
if it is just the fitting would it not be possible to get a reducer for the rad fitting? Just a thought.
Old Nov 2, 2006 | 10:23 PM
biohazard's Avatar
Get low
ive bneen out driving around for the past hour trying to do that
Old Nov 2, 2006 | 10:24 PM
biohazard's Avatar
Get low
its almost 930, i need my car tomorrow
Old Nov 2, 2006 | 10:30 PM
HackAbuse's Avatar
If you really need it that badly, improvise.
Duct tape, anything, get that bitch sealed
Old Nov 2, 2006 | 10:32 PM
Good luck, sorry about the rad screw up.
Old Nov 2, 2006 | 10:34 PM
rally's Avatar
Dude that sucks. Unfortunatly i've never heard of a reducer or expander (?) for tranny cooler lines. I hope you find something for it.
And don't listen to hack, duct tape will fail. Use J.B. WELD and a CRAP LOAD of LOCTITE.
Actually thinking about it (if you never want to get the lines off again) you can fill in the "void" space with J.B. Weld and it'll never leak or move for that matter.
Old Nov 2, 2006 | 10:50 PM
HackAbuse's Avatar
JB Weld works
Old Nov 2, 2006 | 11:24 PM
biohazard's Avatar
Get low
brand new raidiator im not doing it....... can somone with a 2.2 auto do me a fav...... look at the lines for the tranny cooler.... on the backside of the raidiator on the drivers side, the steel lines..... is there a huge ass washer like the size of a silver dollar, and rlly thin on your raidiator where the lines connect?
Old Nov 2, 2006 | 11:36 PM
denniss's Avatar
When you opened the box are you sure the fittings didn't fall out? Aftermarket radiators usually come with any adapters you would need. sometimes they are taped to the inside of the box. I haven't really looked, but there might be reducers in your old radiator that you can remove and use in your new radiator. I know it dosn't help tonight but look in the phone book and find a radiator shop or Possibly a NAPA store in your area and see if they have what you need. I don't think you will find adapters anywhere else. The place you bought it from should have them too. A GM dealer woud not have them because the OEM radiator would come with them.
As a temperary fix you can push the nuts on the trans lines back, (don't put the hose over the fittings because they will leak) and hook the two lines together with a short piece of hose (a strong hose like fuel line) and hose clamps. Be sure to clamp them, there is a lot of preasure in the lines. You could also tear the plastic tank off the old radiator and hook the lines back to that. The cooler is just a big tube inside the tank. I don't know if any of this makes sense but it might get you by till you get the parts you need.
Dennis
Old Nov 2, 2006 | 11:49 PM
denniss's Avatar
I guess I didn't read too close, it's past this old mans bed time! You have an OEM radiator? Was It a GM dealer you bought it from? If it is OEM it should fit without any adapters. I am a little confused as I have put in 2 GM Cobalt radiators with no problem.
Dennis
Old Nov 2, 2006 | 11:54 PM
biohazard's Avatar
Get low
Dennis
its an oem radiator but it wasnt from a dealer it was from a site. i forgot the name.... ill look to see if there are any reducers in the boxidk i might just go to the dealer and buy a new radiator
Old Nov 3, 2006 | 12:09 AM
biohazard's Avatar
Get low
ya there arent any fittings in the box, i might return this and buy one from the dealer and just pay a sht load
Old Nov 3, 2006 | 12:28 AM
tricky1's Avatar
When I replaced the radiator in my neon the tranny cooler lines were a TIGHT fit, a lil bit of elbow grease and some lube later they were on. Just as a note I got new unbent line from Autozone because I had to cut the old lines since they were seized on.
Old Nov 3, 2006 | 12:39 AM
biohazard's Avatar
Get low
my lines are way to small though.... they dont even catch the threds in the new radiator, they slip right in
Old Nov 3, 2006 | 12:45 AM
YellowLT's Avatar
Lookey Here
http://www.trademotion.com/partlocat...=2&catalogid=1
Old Nov 3, 2006 | 12:50 AM
biohazard's Avatar
Get low
Originally Posted by YellowLT
thnx but thats way over priced
Old Nov 3, 2006 | 07:03 AM
denniss's Avatar
Just a thought, but you could buy an auxilirary trans cooler and just hook your lines to it and eliminate the cooler in the radiator. It would look like a small radiator and mount in front of the AC condensor. The rad won't leak through the holes for the lines but you should plug the with something. I think this would be the fastest way to get your car on the road. I will check the price and avalability of a GM radiator today. Ican get it for 15% over cost if that would help you. I would think probably Monday or Tuesday would be the earliest you could get one though. I don't think any dealers will stock one. Iwill try to post the price at lunch time.
Dennis
Old Nov 3, 2006 | 08:27 AM
css9450's Avatar
That's an option as well.... Run new lines from the tranny to the radiator. But it would be time-consuming; it takes a while to get everything bent and cut so it fits perfect.
Old Nov 3, 2006 | 11:15 AM
biohazard's Avatar
Get low
i tried to use some pipe fittings and size down the hole a bit, didnt work.,.... ill be waiting on that raid price lol....
Old Nov 3, 2006 | 01:06 PM
biohazard's Avatar
Get low
i just got back , ordered one fomr my dealer, it was 300 but *** it i need it asap and itll be in at 8 am tomorrow morning
Old Nov 3, 2006 | 07:40 PM
biohazard's Avatar
Get low
i just herd that the lines are quick disconnect for the trans cooler.... is it like tjhis on any of yours? mines not
Old Nov 3, 2006 | 11:17 PM
denniss's Avatar
I am sure I have removed a Cobalt radiator with threaded fittings, Thats why I was surprised today when I looked at two that had quick connect fittings. Must be a change on newer cars I guess.
Dennis
Old Nov 4, 2006 | 01:16 PM
biohazard's Avatar
Get low
my new one had quick disconnects.... i unscrewed them and wala it fit..... its working fine, time to reassemble
riceburner
Dec 24, 2012 03:47 PM
nitr0racing21
60
Jul 8, 2008 10:40 AM
biohazard
Jan 8, 2007 06:57 PM
