injen install HELP
Old Aug 11, 2006 | 09:04 PM
OniMirage's Avatar
injen install HELP
so im installing it and none of the write ups help me at all ... it seems like i have twice as many screws and buttons than anyone else so far my maf was nearly impossible to get to and now my situation is that the damn vibra mount doesnt want to screw on the more i turn the more i think it wants to strip wtf do i do???????????????????????
Old Aug 11, 2006 | 09:06 PM
OniMirage's Avatar
sethallen's Avatar
i didnt even use the vibra mount....1000 miles later and no problems or rattles or noises
Old Aug 11, 2006 | 09:08 PM
OniMirage's Avatar
double bump
Old Aug 11, 2006 | 09:09 PM
OniMirage's Avatar
omg hax bump
Old Aug 11, 2006 | 09:11 PM
OniMirage's Avatar
where the fu#$ is everyone bump
Old Aug 11, 2006 | 09:12 PM
OniMirage's Avatar
Old Aug 11, 2006 | 09:14 PM
OniMirage's Avatar
bump token
OniMirage's Avatar
another bump
Old Aug 11, 2006 | 09:15 PM
06rallyss's Avatar
i dont under stand if you take the intake out than it should be no problem to get to the harness took a little bending to get to but it can be done and my vibramount screwed rate on i now this wasnt much help but it will keep your thread alive a little longer good luck bro
Old Aug 11, 2006 | 09:16 PM
BACK2GM's Avatar
just use some washers instead of the vibe mount it works just fine.
Old Aug 11, 2006 | 09:17 PM
OniMirage's Avatar
the mount comes with a washer i cant go out and buy some with my car in this state
Old Aug 11, 2006 | 09:18 PM
BACK2GM's Avatar
If you have a hack saw cut the mount in half.
Old Aug 11, 2006 | 09:19 PM
OniMirage's Avatar
my neigherbor has one but he works evenings ack everything is going against me
Old Aug 11, 2006 | 09:20 PM
BACK2GM's Avatar
How are you installing it threw the wheel well?
Old Aug 11, 2006 | 09:27 PM
OniMirage's Avatar
BACK2GM's Avatar
When you put the elbow on the tb only put enough to get the hose clamp to tighten down same with the the inake side into the elbow you need every inch you can to pull it down to get
the bracket on the vibe mount.
Old Aug 11, 2006 | 09:29 PM
OniMirage's Avatar
im talking about the vibra mount i could care less abou the rest i know how that part is done
Old Aug 11, 2006 | 09:30 PM
BACK2GM's Avatar
Is that as far as the mount goes in?
OniMirage's Avatar
and another
Old Aug 11, 2006 | 09:31 PM
OniMirage's Avatar
no i can tell it can go more just by eye ballin it but now that it is getting close to the bottom it feels like it wants to give
Old Aug 11, 2006 | 09:32 PM
OniMirage's Avatar
standard bump
Old Aug 11, 2006 | 09:34 PM
OniMirage's Avatar
would it break if i kept going?
Old Aug 11, 2006 | 09:36 PM
OniMirage's Avatar
has anyone actually installed one of these with the vibra mount?
Old Aug 11, 2006 | 09:37 PM
OniMirage's Avatar
install help bump
