Intercooler coolant = white smoke
The coolant from the intercooler loop is somehow being combusted.
Symptoms:
- When I fill the system, I start blowing white smoke.
- Looks exactly like a head gasket blew, but engine cooling system is fine.
- Coolant disappears from the IC system, no more white smoke.
I've disconnected the IC pump for now to avoid burning it out.
My mechanic is not familiar with the IC system, so I'm looking for some help here... what should we be looking at? Intake manifold gasket? Or something else?
Darryl
06 SS/SC
Symptoms:
Darryl
06 SS/SC
What I would suggest is completly remove your intake manifold (You'll have to do that to get to the lam cores and o rings) and get some hoses to hook to the coolant lines. Fill the cooling cores (Lam cores) up with water, and see if you can find where it's leaking from.
I did that after I did my dual pass endplate mod, to make sure it isn't leaking.
If that leak gets too bad, it can cause hydrolock in your engine and RIP LSJ
we are only talking about -15 (Complete perfect vacume) to +15 (Or 18 depending on S/C Pulley and boost limiter options) of pressure in PSI anyways.
