Intermittent power steering loss
I have been getting a sporadic loss of power steering (along with the warning display) It will go out here and there. I either have to pull over and restart the car for it to go away, other times it happens when I'm parked. I only see a recall for the 2010 cobalt, so I'd be surprised if my 2006 is covered. What is the main culprit of these issues? Is it the motor itself or something in the steering column?
I have an 06 and I had the recall work done as well. However, this problem is new and seeing as I had the recall work done surely it's not the same issue as what sparked the recall?
What did they replace on the recall? Never had to take a car in for a recall believe it or not. Do they check the vehicle's VIN to see if the replacement was done? I bought the car used a couple of years ago. The previous owner kept receipts of the work done including the key cylinder, but nothing on the power steering.
jdbaugh, I've heard of people having a reoccurring issue with a component after a recall, some weren't so lucky to have a part replaced again for free. From what I've read, the power steering issue can either come from the motor itself, or the steering shaft. I suppose it's worth a try to see if they'll fix the issue for free. When did you have the recall work done?
I had the steering recall done a long time ago. I assumed they replaced the power steering motor but I'm not for sure. Since then I have had the ignition recall as well as the gas tank recall completed.
