key won't come out of the ignition
Old May 12, 2010 | 12:23 AM
08-cobalt-sport's Avatar
ok im driving home from my friends house, pull in my drive way throw it in park and reach for my key and try turning it to the off position and its stuck. so im playing with it trying to pull it out but its not bugging. so now my car is left in drive sitting in my drive way. lol
ANY IDEAS WHY ITS DOING THIS????????
Old May 12, 2010 | 12:31 AM
scottyguy401's Avatar
Dead battery or steering wheel needs to be tilted
Old May 12, 2010 | 12:37 AM
Mr_Slobalt's Avatar
remove the small cover at the bottom of the column behind the wheel and push a white button to release the key
I would bet on the shifter having an issue....there's a metal contact on the passenger side of the shifter at the bottom that's not touching the switch....remove the cover to access this switch and move the switch contact until it releases the key....the only fix for this is a new shifter unfortunately due to a peg being broke/missing
I'm not saying this will fix your issue, but I'm trying to help you diagnose.
Old May 12, 2010 | 12:42 AM
Originally Posted by Mr_Slobalt
remove the cover at the bottom of the column and push a white button to release the key
I would bet on the shifter having an issue....there's a metal contact on the passenger side of the shifter at the bottom that's not touching the switch....remove the cover to access this switch and move the switch contact until it releases the key....the only fix for this is a new shifter unfortunately due to a peg being broke/missing, unless you can somehow move the metal contact over its peg
i tried that but still nothing. so i just pulled the injection fuse to turn off the car, so im just going to go to the dealership tomorrow to see what is going on.
Old May 12, 2010 | 12:43 AM
Mr_Slobalt's Avatar
the button trick didn't work?
well, then you may have another issue like the ignition cylinder being froze up inside it's housing...another common problem
EDIT: another thing too, there was a recall on these for the shifter cables right? maybe it's not in park all the way and the cable needs adjustment
Old May 12, 2010 | 12:48 AM
tunerkreations's Avatar
mine did that to all you have to do is turn the steering wheel back and forth and wiggle the key it comes right out what happens is the steering wheel locks up thus the key locks to its really simple its just another gm flaw
Old May 12, 2010 | 12:50 AM
hmmm ok let me try that
Old May 12, 2010 | 12:56 AM
didn't do any thing. still stuck lol
ChevyRockstar's Avatar
if the steering wheel locked its gonna take ***** to unlock lol
Old May 12, 2010 | 12:58 AM
HunterKiller89's Avatar
did the key at least turn to the Off position? or is it stuck in the On position?
basically, can you turn it, but not pull it out? or neither?
Old May 12, 2010 | 01:03 AM
stuck on the on postion
Old May 12, 2010 | 01:06 AM
turn your wheel hard boths ways well wiggling the key trust me, its a bitch to unlock the steering, i dont care how hard you try use *****
Old May 12, 2010 | 01:16 AM
my steering wheel is unlocked and i am wiggling the key but still nothing
Old May 12, 2010 | 01:18 AM
Then it must not be going into park all the way
Old May 12, 2010 | 01:24 AM
idk i was throwing it into park then neutral and back and forth but still stuck in
Old May 12, 2010 | 01:36 AM
army_greywolf's Avatar
There is a recall for this they will ONLY replace the part once it's broken. It is a metal contact in the shifter, sometimes it is possible to jiggle it in park to get the key out, you will hear an audible click when you get it right going from drive to park.
Old May 12, 2010 | 02:21 AM
when its just the park position switch (which is what the TSB is for), it should still allow the OP to turn the key to Accessory and turn off the engine....it just wont go all the way to Off and come out.
Old May 12, 2010 | 06:57 AM
G5 Pursuit guy's Avatar
To remove your key, just press the shifter button a few times. You will hear a click, and then you will be able to turn the key all the way back to remove it. It is a problem with the shifter.....I had mine replaced 2 years ago.
Old May 12, 2010 | 09:23 AM
Arwes's Avatar
I posted a thread with the same problem. Anyone know which year model shifter to get that doesn't have the problem? Mine's a 2005, did they fix it with the 2007 & up?
Old May 12, 2010 | 09:31 AM
kdawg1512's Avatar
If your still having problems take your car for a ride for about 5 10 min and try turning off your car that works for me all the time and it dose happen to me quite offten
Old May 12, 2010 | 09:23 PM
I have an 2008 Cobalt and i went to the dealer ship and they fixed it. my Tumbler retainer came out of the cylinder and it caused it to not turn back.. they fixed it for free, so if your car still gets stuck in the ignition send it in. its under warranty so y not!!!!
Old May 12, 2010 | 09:29 PM
Arwes's Avatar
LOL mine's an '05, it's been out of warranty for two years. :p
Old May 12, 2010 | 09:55 PM
i think i found a link to help you out with the problem
http://www.ricksfreeautorepairadvice...93-gm-vehicles
Old May 13, 2010 | 12:34 AM
insylem's Avatar
Automatic or manual?
I had that problem with my AUtomatic Dodge shadow,
and the principal would be the same in any car. Occasionly
it would not go all the way into park, and it would cuse the
key to get stuck. I would bump the shifter into park and
it would release the key.
Sometimes I'd have to turn the car on / off a few times to get
the key out, try that too, esp if your manual.
Old May 13, 2010 | 12:47 AM
I've seen this a half dozen times. MY car is manual and my ignition was stuck on, not even allowed into acc. they replaced the lock cylinder. The auto cars have a switch in the shifter that breaks contact as it wears. thus the key gets stuck. Anyways, good luck to the op, take it to the dealer.
