knock/clunk noise
Ive been having a horrible sound while shifting and/or when applying the gas.
Replaced: 2x axles 2x complete cont arm 2x sway bar links Complete suspension New shifter |
Just going on a limb here, seems your done just about everything except the problemm.. lol but what about motor/trans mounts? I mean at this point and time that only makes sense..
I was thinking about that but how to figure out which one?
im no expert here with trans/motor mounts with these cars, so i cant help you into detail.
from my stand point, after suspension parts i would have turned to the mounts. I guess, does the sound come from way in the front, middle, far back ? if you can narrow down where the sound is comming from that would help. BUT from what i see lots of, tranny mounts are the first people replace with their balts. again i cant directly tell you why, but its definatly more common then the motor mounts. |
Ok thanks alot
Originally Posted by josh6854
(Post 7303532)
Ok thanks alot
The stock mounts on these cars suck, I had the problem with my stock ones getting worn out. And my zzp inserts are getting sloppy now, I am going to try the rotated mounts this time around.
