knock/clunk noise
knock/clunk noise
Ive been having a horrible sound while shifting and/or when applying the gas.
Replaced:
2x axles
2x complete cont arm
2x sway bar links
Complete suspension
New shifter
Replaced:
2x axles
2x sway bar links
Complete suspension
New shifter
Just going on a limb here, seems your done just about everything except the problemm.. lol but what about motor/trans mounts? I mean at this point and time that only makes sense..
im no expert here with trans/motor mounts with these cars, so i cant help you into detail.
from my stand point, after suspension parts i would have turned to the mounts.
I guess, does the sound come from way in the front, middle, far back ? if you can narrow down where the sound is comming from that would help. BUT from what i see lots of, tranny mounts are the first people replace with their balts. again i cant directly tell you why, but its definatly more common then the motor mounts.
The stock mounts on these cars suck, I had the problem with my stock ones getting worn out. And my zzp inserts are getting sloppy now, I am going to try the rotated mounts this time around.
DANRICKARD
10-01-2015 12:08 AM
