knock/clunk noise
Old 03-18-2014, 10:24 PM
josh6854's Avatar
knock/clunk noise
Ive been having a horrible sound while shifting and/or when applying the gas.
Replaced:
2x axles
2x complete cont arm
2x sway bar links
Complete suspension
New shifter
Old 03-18-2014, 11:20 PM
05g5's Avatar
Just going on a limb here, seems your done just about everything except the problemm.. lol but what about motor/trans mounts? I mean at this point and time that only makes sense..
Old 03-19-2014, 12:03 AM
josh6854's Avatar
I was thinking about that but how to figure out which one?
Old 03-19-2014, 12:06 AM
05g5's Avatar
im no expert here with trans/motor mounts with these cars, so i cant help you into detail.
from my stand point, after suspension parts i would have turned to the mounts.
I guess, does the sound come from way in the front, middle, far back ? if you can narrow down where the sound is comming from that would help. BUT from what i see lots of, tranny mounts are the first people replace with their balts. again i cant directly tell you why, but its definatly more common then the motor mounts.
Old 03-19-2014, 12:18 AM
josh6854's Avatar
Ok thanks alot
Old 03-25-2014, 05:26 AM
jcobaltss's Avatar
Originally Posted by josh6854
Ok thanks alot
I had the same problem and it turned out to be a loose tranny mount
Old 03-25-2014, 06:49 AM
mitchk90's Avatar
The stock mounts on these cars suck, I had the problem with my stock ones getting worn out. And my zzp inserts are getting sloppy now, I am going to try the rotated mounts this time around.
biniecki
10-25-2015 02:23 PM
Jimmy Beilfuss
10-05-2015 04:18 AM
jimbofug007
10-02-2015 12:06 PM
DANRICKARD
10-01-2015 12:08 AM
Tupp
09-30-2015 08:18 PM
Quick Reply: knock/clunk noise
