Lean On a 2.2
Ok, It's happened three Times now, It's actually on right now. First, was at the AutoX, Second was on a bank off ramp at high speed, Lastly was again on a banked on ramp at high speed. Only thing i can think of is it's losing pick up in the tank, the last one I did notice I was under a 1/8 of a tank of gas. Any one have any other Ideas?
Fuel Pump?
Are you modified? |
Did you have the pedal to the floor?
I have a friend with a dodge avenger, and if he takes a high speed turn while at WOT with low fuel, his car will actually stall out |
crap gas and a puddle of mudd in the tank? also, if it's winter, it's not uncommon for water to condense in the tank and if you have low fuel get some good old h2o in your fuel.
First two Times, were in the summer, I have Intake and Exhaust, I run Shell V-power.
Wasn't Wot but holding at like 5k rpms |
It usually means you have more air coming into the engine than is being accounted for. Check for intake leaks.
Check the gas cap gasket.
I have an Idea its that AEM intake of yours, they've been known to do that
Ok swapped the intake out still doing it.
