Lean On a 2.2
Old Dec 6, 2006 | 03:44 PM
YellowLT's Avatar
Lean On a 2.2
Ok, It's happened three Times now, It's actually on right now. First, was at the AutoX, Second was on a bank off ramp at high speed, Lastly was again on a banked on ramp at high speed. Only thing i can think of is it's losing pick up in the tank, the last one I did notice I was under a 1/8 of a tank of gas. Any one have any other Ideas?
Old Dec 6, 2006 | 03:54 PM
NJHK's Avatar
Fuel Pump?
Are you modified?
Old Dec 6, 2006 | 04:08 PM
HackAbuse's Avatar
Did you have the pedal to the floor?
I have a friend with a dodge avenger, and if he takes a high speed turn while at WOT with low fuel, his car will actually stall out
Old Dec 6, 2006 | 04:10 PM
joeworkstoohard's Avatar
crap gas and a puddle of mudd in the tank? also, if it's winter, it's not uncommon for water to condense in the tank and if you have low fuel get some good old h2o in your fuel.
Old Dec 6, 2006 | 04:30 PM
YellowLT's Avatar
First two Times, were in the summer, I have Intake and Exhaust, I run Shell V-power.
Wasn't Wot but holding at like 5k rpms
Old Dec 6, 2006 | 07:26 PM
Witt's Avatar
It usually means you have more air coming into the engine than is being accounted for. Check for intake leaks.
Old Dec 6, 2006 | 11:08 PM
Halfcent's Avatar
I'm old school
Check the gas cap gasket.
Old Dec 6, 2006 | 11:12 PM
rally's Avatar
I have an Idea its that AEM intake of yours, they've been known to do that
Old Dec 11, 2006 | 01:31 PM
YellowLT's Avatar
Ok swapped the intake out still doing it.
turbochargedss2012
Sep 20, 2023 12:17 PM
tomj77
Oct 4, 2015 11:39 AM
Tupp
Sep 30, 2015 08:18 PM
Dylan Johnson
Sep 30, 2015 08:57 AM
DocSvensk
Sep 27, 2015 02:24 PM
