Limp mode + P0069
Old Mar 19, 2009 | 03:10 AM
Dainslaif's Avatar
Limp mode + P0069
So, I was cruising home from an evening at the track, had a preexisting P1182 code (Supercharger Inlet Pressure Sensor Performance ECM), downshifted into third to do a pull, and right when I started laying on the gas I immediately hit limp mode. Pulled the codes off the car and now had P0069 (Manifold Absolute Pressure - Barometric Pressure Correlation ECM) in addition to the P1182.
http://img.photobucket.com/albums/v1...2/Car/Limp.png
I reset the DTCs and the engine fired up and drove like normal the rest of the way home. I looked around and had seen other folks with P0069 codes, but none of them went into limp mode.
Thoughts?
Old Mar 19, 2009 | 03:14 AM
Jrhdpaintball's Avatar
i had sent my manifold out to get work done to it... and when it came back i put it on, drove it about 3 miles with no problems.. then mine went into limp mode with that code... i guess from shipping knocked around the map sensor and it took a ****... replaced it with my spare and everything is good...
Old Mar 19, 2009 | 12:20 PM
Dainslaif's Avatar
So in speaking with another tuner, he suggested the two codes are actually related. Does the SC inlet pressure sensor actually do comparisons to the MAP sensor? I just assumed the P1182 was a bullshit code since my car used to throw it all the time when I was stock, but I've been getting it the past few days.
InfraRedline
Drag Racing
35
Sep 29, 2015 02:09 PM
speedlimit
Site Development and Help
Sep 25, 2015 08:04 AM
Dustonian131
Sep 23, 2015 08:03 PM
bucks121
Sep 12, 2015 07:39 PM
