A little help needed. Evap codes
Old Nov 9, 2014 | 04:18 PM
Pitbull2o08's Avatar
So the last week I've been getting P0446. I have been able to clear it only for it to come back 2 days later, every time. Today I removed the canister and blew into it, only to meet 100% resistance, and was unable to blow through it, meaning the canister is still good, right? Unless it is stuck closed? Anyway, I reinstalled it and ordered the part anyhow. I tried to clear the code again only to see two codes this time! And I was unable to clear P0446 this time! Car is idling a little high, around 900-1000 mark but slowly comes down. I have pictures of my log I will attach, but any help is appreciated.
Old Nov 9, 2014 | 04:20 PM
Old Nov 9, 2014 | 04:21 PM
Old Nov 9, 2014 | 06:21 PM
Little help?
Old Nov 9, 2014 | 07:28 PM
Mr.Tozzi's Avatar
evap purge solenoid maybe?
Old Nov 9, 2014 | 08:17 PM
Im replacing that. But when I blew through it, it was fine.
Old Nov 9, 2014 | 09:19 PM
tomj77's Avatar
Doesn't matter if u can't blow through, it may just not be opening.
Old Nov 9, 2014 | 09:25 PM
tomj77's Avatar
Ok that is a tank pressure code. Not enough pressure so u have a leak somewhere. Fist check ur gas cap to make sure it's on properly. If that don't work, try replacing the tank pressure sensor on the canister , black thing under ur car back behind ur gas tank. If u changed the solenoid on the intake, thAt probably isn't ur issue.
Old Nov 10, 2014 | 06:08 PM
I'm currently waiting on that intake solenoid to get on tomorrow. I think I'll just replace that and the gas cap for good insurance. Then look into the switch under the tank. Do have a picture?
Old Nov 10, 2014 | 06:11 PM
Should I return that intake evap purge solenoid?
Old Nov 25, 2014 | 09:30 PM
Replaced evap purge solenoid on manifold, and code P0446 came back 4 days later. Any ideas?? Please help....
Old Nov 25, 2014 | 11:13 PM
tomj77's Avatar
try replacing the gas tank pressure sensor. and the evap vent solenoid, both are located on the evap canister behind the gas tank.
Old Nov 26, 2014 | 12:00 AM
nathan112i's Avatar
^this i ended up replacing both the purge solenoid and evap vent solenoid before my codes went away for good.
Old Nov 26, 2014 | 06:15 AM
Do you have a pic of those two components?
Old Nov 26, 2014 | 09:46 AM
tomj77's Avatar
I have a vent solinoid at home and possibly my old tank pressure sensor. U can look me up at rock auto.
Old Nov 26, 2014 | 09:55 AM
tomj77's Avatar
Goto rockauto.com and look for this stuff
AIRTEX / WELLS Part # 2M1084 More Info {#15788844, 15795021, 17114055, 21993142, 22865590, 25321964, 25932573} - evap vent solinoid
May Require 1P1793 Jumper Harness Connector for Installation because of OEM Redesigned Vent Solenoid
I will need the connector to cause the solinoid has different plug than original, they all come like that now .
ACDELCO Part # 13502903 - fuel tank pressure sensor
Old Nov 26, 2014 | 10:45 PM
Sweet, I'll check it out when I get home.
Old Nov 28, 2014 | 08:23 PM
It's up here?
Old Nov 29, 2014 | 02:55 PM
tomj77's Avatar
yes that's the evap canister. the vent solenoid is the one with the red plug and the tank pressure sensor is the white plug
Old Nov 30, 2014 | 11:37 PM
Sweet! That looks easy enough. I hope that fixes my code for good. So I really need that extension cord thing?
Old Dec 2, 2014 | 11:06 AM
tomj77's Avatar
Yes , the solinoid has different plug now that they updated it
